![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
HKS, RacePak, Megan Racing, Votion, TONS MORE-OVER 100 PARTS!*!*!*!*!*
MAKE AN OFFER...WORST I CAN SAY IS NO!
HKS EVC VI Boost Controller - BRAND NEW IN BOX! - $550 (Retail: ~$700) ![]() ![]() ![]() RacePak Vnet EFI Interface Module for AEM - This allows you to hook up an AEM ecu to a RacePak cluster - BRAND NEW IN BOX! - $300 (Retail: ~$375) ![]() Votion Liquid to Air Intercooler Kit (Custom order...not sold as a kit) - Capable of supporting up to 1000+hp - BRAND NEW IN BOX! - Kit includes: 26X7X3.5 Heat Exchanger, Fill Cap, Ice Box, Bosch pump, Dual 7" fans, 15X6.5X6 Long Flow Intercooler - $750 ![]() SR Timing Chain Tensioner - ~3k miles - Perfect Shape - $50 ![]() Cam Angle Sensor Gasket and O-ring - Perfect Shape - $5 ![]() Intake and Exhaust Cam Gear Bolts - PERFECT SHAPE! - $3 each ![]() SR20 Head Bolts - Used - $15 ![]() KU Engineering Style S13 Intake Manifold - Never Used (just sitting around for about 3yrs, but the last owner drilled injector port 1 larger to put larger injectors in but then sold it to me...costs about 60 to do it to the other 3 or 40 to correct port 1) - $100 ![]() SR20 Upper Oil Pan - SOLD! SR20 Oil Pump - SOLD! SR20 Oil Screens (2 sets) SR20 Rear Crank Case Cover (4) SR20 Oil Block Galley w/ Sensor - SOLD! ![]() SR Main Cap Girdle - PERFECT SHAPE - $15 each ![]() SR Coolant Tubes - $20 SR Short Coolant Tubes - $5 SR Temp. Sensor Housing - $10 SR Thermostat Housing - $10 SR Coolant Inlet - $10 SR Coolant Complete Setup w/ Sensors - $45 ![]() OEM SR20VE P11 Valvetrain (IN+EX Valves, Springs, Cams, Gears) - 15,000 Miles - PERFECT! - Valves - SOLD! Springs - $25 Retainers - $15 Camshafts - $50 Gears - $10 ![]() SR20DET AAC Valve - PERFECT SHAPE - $30 ![]() S14 SR Valve Cover w/ Coil Pack Cover - Perfect Shape - $160 ![]() stock KA24de airbox intake system and Filter is still clean (came from a 98' kouki) - PERFECT SHAPE - $50 ![]() S13 Non-ABS Driveshaft - Pick up only - Used - $90 ![]() S13 SR Transmision - Pick up only - Roughly 30k miles - PERFECT SHAPE - $125 ![]() S13 SR Nismo Transmission Mount - Used - $60 ![]() S13 SR Bell Housing - No cracks - $40 ![]() S13 SR release bearing - Good Condition - $10 ![]() S13 SR Clutch Fork - Perfect Shape - $20 ![]() SR20 Timing Chain guide - Perfect Shape - $10 ![]() S13 SR Valve Cover Baffeling - Great Shape - $10 ![]() SR20 Coilpack Gaskets - NEW - $3 each ![]() S13 SR20 Intake Gasket - PERFECT SHAPE - $10 ![]() S13 SR20 Valve Cover Gasket - Perfect Shape - $15 ![]() Injector Gasket O-rings - Perfect Shape - $3 each ![]() SR20 Rear Main Seal - New In Box - $18 ![]() (8) SR20 Hydraulic Lifters - Perfect Shape - $5 each ![]() Megan Racing SR T3/T4 Exhaust Manifold - NEVER USED - $90 ![]() SR OEM Exhaust Manifold - Perfect Shape - $40 ![]() SR20det Exhaust Gaskets (t3, T4, Exhaust mani) - Perfect Shape - $20 ![]() Crank Pulley Bolts (2) -Perfect Shape -$5 ![]() Transmission Mount Brackets - Perfect Shape - $15 each ![]() Alternator Brackets - Perfect Shape - $20 each ![]() Knock Sensor (4)...one doesn't have a sub-harness - Perfect Shape -$25 each (15 for the one without the sub-harness) ![]() Godspeed Arm - $15 S13 Rear Links - $10 each S13 Front Lower Control Arm - $30 ![]() (2) o2 Sensor Simulator - one was touched with dirty hands, then I put on gloves - NEW IN BOX - $33 (each) ![]() \/ \/ \/ 350Z PARTS \/ \/ \/ 350z OEM Hatch w/ Glass - Perfect Shape - $300 ![]() 350z OEM Hood - Perfect Shape - $250 ![]() 350z OEM Fenders - Perfect Shape - $150 ![]() 350z OEM CD009 Transmission Gears (I switched to OS Giken Gears) - Perfect Shape -15k Miles - $350 ![]() 350z Master 1 1/16th - Perfect Shape - $45 ![]() 350z Brake Booster - Perfect Shape - $100 ![]() 350z Arms - Perfect Shape - $50 ![]() 350z 03' tinted tail lights - Great shape - $75 ![]() These are all the make an offer items...i dont want or need them so just make an offer...pictures of these upon request. \/ \/ \/ 2005 WRX (less then 20k miles on items)\/ \/ \/ OEM Air Box Setup OEM Downpipe OEM Full Exhaust OEM Uppipe OEM Turbo Heat shield \/ \/ \/ Auto 200SX SER Engine Part Out \/ \/ \/ Head (currently has valves, springs, retainers, and keepers but can remove if buy requests) Rocker arms Oil tubes in SR head Intake and Exhaust cam gears Valve Cover EGR valve (in WORKING order) distributer (in WORKING order) Headers Injectors w/ Fuel rail Intake Manifold (perfect Condition w/ all connectors and hoses) (3) Pistons (3) Rods Water Pump Water Pump pulley oil filter block crank pulley Coolant tubes Coolant outlet Lower Oil Pan Oil Pan baffling Timing chain tensioner Flex Plate Auto trans gasket Alternator bracket intake bracket power steering bracket ac bracket Auto 200sx Engine Harness (completely uncut) injector harness tps (throttle position sensor) Thank You For Looking!
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 12-25-2013 at 07:47 AM.. |
