Old 01-04-2014, 11:58 AM   #1
oskie
oskie is an unknown quantity at this point
Blow off valve installation query
Guys, I have a query before installing my recirculating blow off valve. On my cold pipe I have vacuum line going to the throttle body(as illustrated in the photo) and I plan to install my blow off valve near it. Would that be fine? Or do I need to block off that vacuum line when I install my bov? Thanks in advance for the help, I'm hoping to learn more from you guys.
oskie is offline   Reply With Quote
Old 01-05-2014, 02:57 PM   #2
badbob2121
badbob2121's Avatar
badbob2121 is an unknown quantity at this point
It would be easier to mount the BOV on the hot pipe, then recirculate it into your intake.
FOLLOW ME ON INSTAGRAM = BOBBY_LS13
badbob2121 is offline   Reply With Quote
Old 01-05-2014, 03:12 PM   #3
Nategreat923
Nategreat923's Avatar
Nategreat923 is making a name for him/her selfNategreat923 is making a name for him/her self
I also mounted mine on the driver side of the intercooler, and had it shoot straight back to the intake.
Edit:
Like this
Nategreat923 is offline   Reply With Quote
Old 01-08-2014, 01:59 PM   #4
shift0246
shift0246 is an unknown quantity at this point
that should be fine as long as you have the right source of vaccum and a long enough hose to make it back to the intake and correct spring installed, what bov is it that you are going to install?
shift0246 is offline   Reply With Quote
Old 01-08-2014, 02:10 PM   #5
waxball88
waxball88 is an unknown quantity at this point
I don't believe connecting to the throttle body nipple works. IIRC i tried it and it didnt work. Connect to the intake, there is a port just TB on the lower intake manifold on the motor side. I am using this for BOV and wastegate reference.
waxball88 is offline   Reply With Quote
