Old 07-26-2013, 01:08 AM   #1
leedrift
leedrift's Avatar
leedrift is an unknown quantity at this point
s13 Blacktop motorset with goodies!
Complete motorset originally from JDMHookup. Mileage unknown, but From what I remember the PO saying and what I drove it it can't be anything over 80k. Wired for an 89-90.
-Polished valve cover that could see some more elbow grease
-Clear CAS cover. Watch that bitch spin!
-Greddy rocker arm stoppers
-Greddy oil relocation and I'll include the bosch filter that has like 600 miles on it
-Megan short throw
-HG replaced about 1.5k ago along with all the gaskets corresponding with that job, head was inspected/cleaned
-Nismo thermostat
-Fancy oil cap
-New pcv valve
-I can't remember the brand but it's a good 6 puck clutch. Stiffer than your pp at the strip club. Might also have a lightweight flywheel too if I remember right. I'm going to pull the trans off in the next few days and confirm all this.
Ran great, solid idle. The only problem with it is the seals are gone on the turbo. I'll be including an entire t25 take-off including the manifold, o2 housing, etc. I have no idea if it's good but I was told it was by the guy who I got it from it is and I trust him. Minimal shaft play from what I can tell. I'll also be including a new manifold gasket. ECU and ignitor chip included. The plugs for the ignitor were relocated near the ecu plug on the harness so it's inside the car. Crank pulley has a little chip. Two holes on the oil relocation will need to be plugged as they had the sending units in them for my gauges. I may find some bolts to put in them.
Video driving it about 2 weeks ago. The only time it got driven after this was to the garage to pull the motor. I borrowed the go pro and had to use the head mount. Don't judge me haha-
S13 sr drive - YouTube
PRICE- 1700 Picked up in Canton IL. I feel that's more than reasonable seeing as the motorset alone from jdmhookup is going for 2200.
leedrift is offline   Reply With Quote
