Old 01-16-2014, 04:23 PM   #1
zlab
zlab is an unknown quantity at this point
stock sr20det running lean under load
iv searched and running out of ideas hope someone on here will be able to shine some light on something i over looked its a sr20det with boltons car starts and runs fine i have a apexi turbo timer a/f read 14.00 @1000k once its warm ill go for a drive i dont even get to 1psi of boost and it reads 20.00 on the a/f pulled plugs they are all light white no boost leaks i could hold 10 psi no problem
cleaned and checked maf 2v signal wire 12v power wire (thinking of re grounding )the negative
checked tps .40 closed 4.5volts wot
fuel pressure 43psi tomie frp adjustable ill give it a quick flip of the throttle and it goes up havent checked under load as the frp is under the hood
walbro pump
my fuel pump is hardwired with its own relay
02voltge stays @.78-80v @1k under load goes down to .01volts
vacuum @1k is 20in
put the fogger on the exhust only fog came out of the wate gate dump tube not sealing complete
have a apexi avcr injector duty is 85% at 1k
coolant temp sensor havent checked but my cluster shows temp so i assume it running correct
kinda stuck thanks in advance for your taking your time to read my post any help is appreciated
zlab is offline   Reply With Quote
