Old 05-11-2014, 11:35 AM   #1
Chihuahua240
Chihuahua240 is an unknown quantity at this point
S14 Fuel Pump Assembly
Hi there, I am having trouble getting the fuel pump assembly out of the tank. I have searched, and threads say it should "slide right up." This is apparently not the case with mine. I can see the metal assembly with the plastic looking thing in the middle of it, and the fuel pump slanted towards the bottom of the tank. However, I pulled on everything inside the tank and it just will not come out.
Is there some type of screw/bolt/clip holding the fuel pump assembly in the tank? And how exactly do I get it out of the tank?
Also, can I reuse the O-ring gasket for the tank cap if I ever manage to remove the fuel pump? Thanks.
Chihuahua240 is offline   Reply With Quote
Old 05-12-2014, 03:59 PM   #2
JBPUSA
JBPUSA is an unknown quantity at this point
there is no bolt, you have to play with it, too bad its not as easy as a s13 tank.
that big o ring should be reusable, its not like the s13 gas o ring that goes out of shape everytime you open it up
JBPUSA is offline   Reply With Quote
Old 05-12-2014, 08:34 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
The pump holder pulls straight up, it just clicks into place with a metal clip/tab, there's no screw or bolt that holds it in place. Just gotta tug and slide it up real hard.
CLICK HERE!!!
