![]() SOLD
I have tried to hold on to this for so long, but sadly I have to sell her this time for sure. I am moving and need to sell. I need to sell it pretty fast, so please make any offer if you are interested. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() MORE PICTURES ON PAGE 2 Mods -------------------------- Front clip s13 with Sr20det black top Hot tanked New valve stems New valve jobs 3 angle valve job New oem piston rings New rods and main bearings New thrust washers New OEM Nissan rebuild gasket New water pump GT2871R Garret Turbo Toda camshafts 264 Tomei rocker arms stopper Brian crower valve springs and titanium retainers Nismo 555c.c injectors + new orings Walbro fuel pump Brand new OEM fuel rail Aluminum hot pipe Hks ssqv blow off valve (adjustable version) Apexi Versa Cruise grounding kit NGK iridium spark plug 7 Tomei oil cap Greddy turbo outlet Koyo Aluminum radiator Greddy radiator cap Samco radiator hose Nismo thermostat Sard fuel regulator Apexi metal head gasket 1.1 mm 87 bore ARP head studs Uras Racing clutch Tomei short shifter Tomei Valve Spark Plug Cover Greddy oil cooler Greddy oil filter Greddy v-spl front mount intercooler Greddy oil pan Circuit sport turbo lines S14 water outlet Oil catch can Greddy cooling panel Custom aluminum intake pipe Apexi Cone Filter Apexi WS catback Trust down pipe Test pipe Brand New Optima Yellow Top Battery (Relocated in Trunk) Suspension ----------------- Work CR KAI 17x9+17, 18x9.5+12 (10mm spacer in the rear to make it +2) Federal 595 215/45/17, 225/40/18 Brembo calipers front and rear Power slot front rotors 300zx e brake set up Tein super drift 10k/8k Tein tie rod + ends Silk Road tension rod S14 5lugs hubs S14 front lower control arm SPL fender braces Shakitto plates Nismo power brace Rash Facture C-Pillar bar Cusco strut bars F+R Cusco ruca’s Cusco toe arms Kazama subframes Volk racing lug nut extended Nismo 60mm wheel studs Cusco 2way LSD + Cusco LSD oil Super Hicas rear sway bar 21mm Brand new Power Steering rack & Fresh Alignment after. Exteriors --------------------- 180sx OEM Kouki bumper 180sx OEM kouki side skirt 180sx OEM kouki rear valances 180sx OEM kouki wing 180sx OEM Kouki taillight 180sx optional Rps13 tail light center Ganador Style Mirrors H4 head lights Brand new Headlight switch Interior ---------------------- Apexi EL2 gauges: Boost, oil press, ex temp Apexi gauge unit controller Apexi avc-r black edition Apexi turbo timer Recaro seats Japanese Maziora steering wheel w/ Nardi Horn Knob Tomei shift knob Hand Made Red Stitch Shift Boot and center console arm rest. Sony head unit Price: SOLD Need sold fast, so make an offer. If you're actually interested, I'll tell you more about the car, or you can come see it. Located in San Diego. Email me for fastest response: [email protected] It has been very lightly driven over the years for a daily driver. Less than 20,000 miles in the 4 years i've owned it. Very well taken care of. The chassis is at 189,000, engine probably about 25,000. Smogged until June. *Things to consider ----------------------- This is a heavily modified car, please be experienced at driving one if you are interested in buying it. It has a 2-way Differential, so it's clunky when turning. Also the clutch is extremely harsh, it's a super-single plate clutch, so it makes noise when you press it. This is not a first car, so I would not suggest showing up with your mom to test drive it. No heat or A/C. The head lights flip up, but don't flip down. More Pictures! ![]() ![]() ![]() ![]()
![]() Last edited by dangarnett; 03-23-2014 at 06:11 PM.. |
