![]() Join Date: Dec 2007
Trader Rating: (41)
![]() ![]() Feedback Score: 41 reviews
s13 headlight issue....
alright well i cant figure out why my passenger lowbeam lights dont work. the driver side works. i try high beams and they both work. the fuses are good. is there a way i can fix this problem?
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
So, the light won't even come on, right?
Eventually, the high beam will go out as well. Just replace the headlight. |
![]() Join Date: Jul 2005
Trader Rating: (29)
1) it could be the bulb.
2) if you swap out the bulbs, and the problem is still there... it may be your headlight switch... as it is a common problem with s13's...
Trader Rating: (41)
its not the bulbs or lamp. i have HID kits. i try low beam and only the driver side works only. when i hook up to high beams, both of them work. im thinking that the wiring could be bad or cut off. i also do have a SR swap too done professionally. i also bought replacement bulbs and its not the bulbs or the ballast.
#5 | |
Trader Rating: (29)
find a friend that has an s13, and try swapping the switches to see if it works or not... I'm like 99% sure that it's the switch. I had the same problem a couple years back... so I went to the junk yard and got a switch for like $5 and tried it... and it worked!
Trader Rating: (41)
alright went to the junk yard and found the headlight switch. switch out my old one and replace it. it was the headlight switch. both of my headlight works now. thanks to you guys!
![]() Join Date: Dec 2006
alright im thread jackin this mo-fo
I got a similar issue on my Wifes car except both low beams work and only driver side H/B works It seems the prev. owner ghetto rigged some fog lights by splicing them into the H-L wire harness (ripped that shit off and replaced the H/L harness) and rubbed the harness through a little bit on the driver side fender harness. I opened the harness from boot to boot and didnt find any other broken wires. all the fuses are good and tried three different bulbs. Now i hooked up My Fluke volt meter and with the harness disconnected im getting about 9-ish volts on the high beams and 12 on the low beams. and when ever i connect the harness the volts drop off. When i hit the high beams the The H/B Dash light doesnt really come on. but when disconnected the head light, the H/B Dash light comes on as normal. Seems like a short somwhere but cant really locate it. Will the light switch cause this? ![]() Edit: also it seems my parking lights dont work either, Brake lights do though
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 02-14-2009 at 07:18 PM.. |
Fixed it.
It was the Head light switch Ripped it apart ans cleaned the contacts Parking lights and everything works now
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 02-15-2009 at 09:50 AM.. |
