Old 08-09-2014, 05:44 AM   #1
Bleakley
Bleakley is an unknown quantity at this point
Tial QR BOV
Okay, I finally wrapped my head around how the QR bov from tial operates. For those who are also familiar with how it works, here is the question I present:
Since it is going off of vacuum and will seemingly ONLY open when the throttle plate is closed, then technically under WOT it will just let my compressor boost into oblivion w/ no cutoff. This will leave me relying solely on my wastegate and I do not think I am comfortable with that. While the design is superb and I like tial's products (hence them being my first choice for a bov), due to this feature I think I am going to have to move to a competitor's bov. :'(
Before I do so though I was wondering if anyone has anymore info/comments/suggestions? Am I wrong and do not fully understand? or No, I fully nailed it and understand? Any help is greatly appreciated. A BOV is the last major component I need and my project will be on the streets.
Bleakley is offline   Reply With Quote
Old 08-09-2014, 08:10 AM   #2
jr_ss
Part throttle and spool into oblivion don't belong in the same sentence. Since boost is throttle dependant, you're not going to boost large amounts. I think you've missed some key things here.
Part throttle, such as cruising, creates a vacuum condition. It also only allows a limited range of RPM. Once again, I think you've over thought exactly what a BOV does and how it all works together.
Old 08-09-2014, 08:22 AM   #3
ultimateirving
ultimateirving's Avatar
You missed it completely. Bov does not regulate boost. Get the tail and be happy.
Z32 with lq4 swap
Old 08-09-2014, 08:32 AM   #4
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
U wont see boost at cruising speeds, even without a bov. Bov's arent even necessary until wot and here they should either be fully closed when on throttle or fully opened while shifting. Bov's dont control your boost levels either.
feito is offline   Reply With Quote
Old 08-09-2014, 10:17 AM   #5
Bleakley
Jr_ss. Probably. Edited my OP (thanks). Sorry for missing key points. Also, thanks for taking the time to answer my questions. I see your posts/expertise all over and I am constantly learning.
Ultimateirving and Feito. Not even a little bit? And I would love to.
And I guess to recap, I'll be going for 12-16 psi with 20-25 psi in the future. Get the tial and I will be alright? I am putting my SR in really soon and will be using the stock T25 and internal gate and will be ramping up my build very quickly, very soon. With the tial BOV is it, basically, giving me what I need? EDIT: I should note, the 20-25 psi will not be with the stock 2560...
Old 08-10-2014, 06:51 AM   #6
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Your bov only blows off extra air. When ur boosting and u let off the as, the throttle body will close. All the air that was going towards the TB now has to go in the opposite direction back towards ur turbo‥ this is known as turbo flutter, which will in theory want to cause ur compressor blades to turn inthe other direction. Having a BOV will blow off all the excess air. This is known to extend the life of ur turbo. Also, sometimes not having a bov can throw off the ecu because of the already metered air.
Luvs2slide is offline   Reply With Quote
Old 08-10-2014, 06:52 AM   #7
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
However some compressor housings have built in anti surge holes which help tofight off the flutter or surging
