Old 08-05-2014, 06:06 PM   #1
shiftin_sideways
shiftin_sideways is an unknown quantity at this point
FS: S13 Parts ka24de engine, trans, kaaz diff & more
EMAIL:Pm is best
PAYMENT: cash
ITEM: KA24DE engine
PRICE: $200
SHIPPING: NO
DESCRIPTION: bought this about 4 years ago as a spare. I was told it runs fine. engine rotates freely by hand. Note: long block means no peripheral accessories i.e. no intake manifold, no distributor, no fuel injectors, etc.
ITEM: SR trans
PRICE: $60
SHIPPING: NO
DESCRIPTION: bought trans about 5 years ago, told doesn't grind and no leaks. never installed to drive and see if it was true. the trans that will be for sale will be the one on the left in picture has orange overflow tube and extension housing. NOTE: trans cross member in picture will not come with trans.
ITEM: KA trans with SR bellhousing
PRICE: $10
SHIPPING: NO
DESCRIPTION: grinds in 2nd gear, had about 100,000 miles on it when pulled. buy it and rebuild the internals for a spare is my suggestion to you. the trans for sale will be the one in the picture on the right.
ITEM: Kaaz 2 way clutch type differential
PRICE: $640
SHIPPING: NO
DESCRIPTION: about 8 years old, less than 10,000 miles on it, has about 10 track events on it. Just replaced the diff oil a month ago.
ITEM: Powered by Max version 1 Knuckles and control arms
PRICE: $300
SHIPPING: NO
DESCRIPTION: I got these knuckles when Powered by Max first started, maybe 4 years ago(?). The tie rod connection on stock s13 knuckle is modified to allow for more angle. There are two settings for tie rod angle. The control arms have had their stock bump stops removed and replace with an adjustable bump stop. The arms have been braced for less torsion of control arms. I drove in the snow once, which explains rust. All work done on knuckles and control arms was done by Powered by Max.
ITEM: Uras Tatsunootoshigo(sea horse)
PRICE: $70
SHIPPING: Buyer Pays
DESCRIPTION: these allow less effort in pulling ebrake to lock up rear wheels. install on rear brake caliper assemblies. Some more info in link.
http://www.rhdjapan.com/uras-tatsunootoshigo-s13.html
picture of stock vs. Uras stock on the left
ITEM: YANACK Steering Rack Collar Set
PRICE: $80
DESCRIPTION: solid aluminum bushings for steering rack on s13.
ITEM: Apexi Afc-Neo
PRICE: $100
DESCRIPTION: Bought 2 years ago, told it works, never tested or powered up to see if works
ITEM: various ecu's from s13
PRICE: $60 each
DESCRIPTION: 2 #24 and 1 #28, one of them is for auto ka24de in s13 and the other is for manual ka24de in s13. you will have to check part #'s to make sure. Jim Wolf Technology may have the part #'s for all the ecu's.
ITEM: steering bushing for s13 from touge factory
PRICE: $40
DESCRIPTION: steering bushing that mounts on steering column above u joint in steering rack. the stock bushing is located near the firewall.
reduces the amount in play between the steering wheel and steering rack.
ITEM: Jdm steering wheel
PRICE: $80
SHIPPING: NO
DESCRIPTION: size 350 mm, semi dished, 6 bolt pattern, color is maziora purple. some paint chipping on back on wheel.
ITEM: HJC AR-10 helmet
PRICE: $160
SHIPPING: NO
DESCRIPTION: size m, hat sizes 7 1/8- 7 1/4, comes with clear visor, gold tinted visor(discontinued by HJC), and helmet bag. Wore for about 10 events. Snell Sa2005
ITEM: Peak performance trans mount for sr or ka
PRICE: $50
DESCRIPTION: made of polyurethane
ITEM: Peak performance inner tie rods with spacer
PRICE: $50
DESCRIPTION: no play in ball joints used for 1500 miles and 3 track events.
ITEM: s13 steering rack
PRICE: $40
SHIPPING: NO
DESCRIPTION: no leaks when pulled, hard lines have no rust
pic below
ITEM: flip up headlights set
PRICE: $20
SHIPPING: NO
DESCRIPTION: complete assembly with motors, last time operated lights lit, went up, but not down, don't know if motor assembly is to blame
pic below
ITEM: s13 stock shifter
PRICE: $5 each
DESCRIPTION: hass clip and plastic retainer intact
ITEM: trans crossmember for manual sr or ka
PRICE: $5 each
DESCRIPTION: comes with factory rubber trans mount in good condition
ITEM: Destruction warehouse shift know
PRICE: $25
DESCRIPTION: threaded for stock s13 shifter, size is about the same as stock s13 shift knob
ITEM: ebrake lever with drift knob, complete ebrake line
PRICE: $30
DESCRIPTION: ebrake lever with attached cables that go all the way to rear calipers, pulled from a car with about 100k miles
also in above picture are wiper arms, turn signal stalk, wiper stock, wiper motor, ash tray, flash, rear defrost, headlight flip switches all $5,willing to ship all
ITEM: 5mm spacer for 4/5x114.3 hub pattern
PRICE: $20 for all four
DESCRIPTION: used once
ITEM: ignition coil for ka24de
PRICE: $20
DESCRIPTION: used to test a no start problem, other than that not used since bought brand new
ITEM: fuel rail for ka24de no injectors included
PRICE: $5
DESCRIPTION: didn't test fuel rail for leaks, just took out injectors for another engine
ITEM: stock s13 axles
PRICE: $30 each
SHIPPING: NO
DESCRIPTION: had about 100k miles on them when pulled, 3 track events
ITEM: stock s13 open diff
PRICE: $20
SHIPPING: NO
DESCRIPTION: taken out of car with 100k miles
Also in above pic, rear lower control arms, starter, and brake calipers(need rebuild) are $5 dollars NO SHIPPING
ITEM: A/C components for s13 KA24DE
PRICE: $5 for everything
SHIPPING: NO
DESCRIPTION: don't know if anything works or leaks
ITEM: key cylinders for s13 hatch(don't know if fits s13 coupe)
PRICE: $10
SHIPPING: NO
DESCRIPTION: key cylinders for both front doors, rear hatch, glove box,and ignition cylinder. all lock and unlock with one key. suggest to re key all locks for a new key so new key won't be so worn down.
Also have a Cusco front strut bar, stock exhaust (after catalytic converter all the way to muffler)with 1 year old muffler , and 15'' tires. I will upload pics as soon as I can.
shiftin_sideways is offline   Reply With Quote
Old 08-05-2014, 09:17 PM   #2
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
If you change your mind in the ac stuff, I'll take it all except the compressor and bracket. Shoot me a PM shipped to 80205 if you want.
Thanks!
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 08-06-2014, 05:19 PM   #3
shiftin_sideways
Pm's replied too
Old 08-09-2014, 12:34 PM   #4
shiftin_sideways
Headlights sold.
Old 08-10-2014, 01:34 PM   #5
shiftin_sideways
A/c stuff sold.
Old 08-10-2014, 03:17 PM   #6
Patputter14
Patputter14 is an unknown quantity at this point
DAM! i wanted that a/c system. haha Great fucking deals man.. interested in the keylock setup, willing to ship to 30518?
dont want glove box lock -_- just doors and hatch!! since mine are all different LOL.
Patputter14 is offline   Reply With Quote
Old 08-13-2014, 07:37 PM   #7
shiftin_sideways
key cylinders and dash buttons sold
Old 08-21-2014, 10:39 AM   #8
shiftin_sideways
uras levers sold
Spacers sold
Old 08-23-2014, 09:37 PM   #9
kdawg2587
kdawg2587 is an unknown quantity at this point
pm'ed you about some items that i need asap!
kdawg2587 is offline   Reply With Quote
Old 09-16-2014, 11:14 PM   #10
PINOYROADIE
PINOYROADIE is an unknown quantity at this point
You still have a stock shifter with the "C" clips?
PINOYROADIE is offline   Reply With Quote
Old 09-16-2014, 11:16 PM   #11
PINOYROADIE
sent you a pm
Old 09-29-2014, 08:40 PM   #12
CSAlltrac
CSAlltrac is an unknown quantity at this point
PMed you about Helmet.
CSAlltrac is offline   Reply With Quote
Old 10-04-2014, 02:39 PM   #13
Swagner
Swagner is an unknown quantity at this point
Sent you a PM!
Swagner is offline   Reply With Quote
Old 10-17-2014, 09:37 PM   #14
jscherf92
jscherf92 is an unknown quantity at this point
Any guess on what shipping would cost on the manual transmission cross member? I really just need the bracket off of that lower one that braces the exhaust.
jscherf92 is offline   Reply With Quote
Old 10-17-2014, 10:13 PM   #15
Night drifte89
Night drifte89's Avatar
Night drifte89 is an unknown quantity at this point
Was that a starter I saw? For sale? Pm me
Night drifte89 is offline   Reply With Quote
