Old 11-19-2014, 10:33 PM   #1
MC.Understeer
MC.Understeer is an unknown quantity at this point
RB25DET NEO 6 part out gt3071r full swap
Video of it running November 16, 2014 before I pulled the swap
Rb25 swap before swap is pulled to sell November . . .: http://youtu.be/De33Eig0O3o
http://images.craigslist.org/00000_b...2Y_600x450.jpg
http://images.craigslist.org/00h0h_4...UU_600x450.jpg
http://images.craigslist.org/01010_1...zs_600x450.jpg
http://images.craigslist.org/00T0T_f...hw_600x450.jpg
http://images.craigslist.org/00808_l...uo_600x450.jpg
http://images.craigslist.org/00g0g_k...4Z_600x450.jpg
This swap is currently in a s13 coupe running and driving without any issues. Once I get some people wanting parts I will make a documented video of the date and time with the engine running and transmission working to supply to any buyers of parts from this listing before any parts are removed. If you are interested in anything such as the engine, all parts can be removed same day within a few hours.
RB25det NEO 6 - LONGBLOCK valve covers to oil pan minus(NO exhaust and intake manifolds)
(block has ACL Main, Rod race bearings and thrust washers with about 4500-5000 miles) $1000
RB25DET 5spd trans in perfect working condition $850
ORC hyper single clutch with lots of life left and low miles $700
One piece steel driveshaft $280
Mckinney Swap mounts $300
Wiring specialties rb25det to s13 harness $400
Apexi SAFC wired into the wiring specialties harness $160 added to the harness or can be removed
Stock rb25det NEO 6 ecu $160
Aftermarket intake manifold $400
Power by max oil filter relocation kit combined with a oil cooler that has less than 3000miles of use, works on sr20det, 2jz and other nissan and toyota's $200
850cc modded top feed injectors $250
Top mount sch40 custom stainless steel manifold setup for twin tial 38mm wastegates $700
Downpipe $160
JDM RSR 3" cat back exhaust with oval muffler in good condition no rust $300
Tial 38mm wastegates $280 each (have two obviously)
GT3071r ball bearing turbo with 4500-5000 miles on it $850
Raw brokerage Front mount intercooler setup $300
Raw brokerage RB radiator with fans $250
RB catch can setup (in picture with fittings) $150
16x8 et30 205/50 16x9 et35 225/50 3 piece Stern wheels made in Japan. No curbing or bends, just need to be sand blasted because they've been spray painted. $500 tires have a good amount of life left.
Sparco offset champion 350mm steering wheel. Only a couple months old. No wear or damage.
$150
The more you buy, the more you save. No trades and prices are FIRM unless you buy multiple items. All prices are very reasonable and if you can't tell by the mod list, I know what these parts are worth and cost new so don't even waste my time trying to haggle with me.
MC.Understeer is offline   Reply With Quote
