Clutch issue?
My cousin took my 98 Kouki out last night in the pouring rain and was doing donuts. After a couple of turns the wheels started gripping and he clutched in and braked. After the car would go into gear without having to depress the clutch pedal. With the car on it can go into 1-5 gears without grinding or stalling while the car is on and not disengaging the clutch but it will grind in reverse.
The clutch bite point was super close to the top and I had issues with the clutch slipping every once and a while while trying to launch the car.
Any help is appreciated and I am currently looking through the "search" function.
After searching around I have concluded there could be 3 or more problems, please tell me if I am missing anything else:
Check clutch master fluid
Check for kinks in clutch line
Check for slave cylinder leak
