![]() Join Date: Jul 2007
![]() ![]() ![]() ![]() Feedback Score: 4 reviews
1990 240sx ka24de coils Isis exhaust unchecked dash
1990 Nissan 240sx clean title! Engine was swapped to a ka24de, the car has Godspeed coil overs, brand new alternator, starter, battery, clutch master cylinder, a dif Teflon coated steel braided clutch line, Isis dual tip 3 inch straight pipe exhaust, drift freaq poly eurothane motor mounts, untracked dash, brand new headlight switch, the cars interior is really clean and is reliable the paint is ehhhhh price is $2100 firm on stock rims
Maybe I'll throw some goodies in to do not offer me $1500 or 1900 u will be denied prices is form Cons The car smokes on take off, car has never overheated or anything on me, it is reliable I drove it daily to school never has given me problems. I don't want another project so I never looked into it could be a simple fix maybe spark if seals or a valve When idling for more then 3 min the Rpms will fluctuate but will return to normal once u drive it. A bit The car has a charging issue never leaves me stranded but sounds like its not charging the battery back up correctly Also when u trie to start it it clicks so after a couple turns it will start Last owner also relocated the battery to the trunk in the past and he drilled through the trunk and punctured the tank so if u fill the car past 3/4 it will splash out Needs a speed sensor ![]() ![]() ![]() ![]() ![]() ![]()
