Old 08-21-2015, 09:30 AM   #1
nddavis2
nddavis2 is an unknown quantity at this point
VQ swapped 240 wiring help
I swapped an '04 VQ35de into my 91 hatch. I decided I wanted to do a tucked wiring harness and finished it up which resulted in it starting without a problem however when pressing the accelerator pedal, it doesn't rev much as it's gone into limp mode. I'm getting the codes below:
P2122 - APP sensor
P2138 - APP sensor
P0222 - TPS
P0123 - TPS
P2135 - TPS
I checked continuity for the accelerator lines and all are good on being pinned correctly and have continuity. Checking voltages they do not get the proper voltage as only 1 gets the 5V signal and not the other that should.
Checked continuity for the TPS and pins 1, 2, 4, and 5 are good however using the FSM image below, I'm having issues understanding what to check.
I know the shielding has to be grounded however nothing is mentioned for pins 3 or 5. I have written down that one goes to Pin 5 on the ECU and the other Pin 44. Can someone verify this is correct? Voltages are not coming across as correct on these either.
Before it's mentioned, I had the ecu checked and it worked fine as it drove my friends car around with no issue.
nddavis2 is offline   Reply With Quote
