Old 09-02-2004, 11:20 AM   #1
AAA240SX
AAA240SX's Avatar
AAA240SX is an unknown quantity at this point
Broken bolt in the head...
Ok, I'm working on my 7MGE, but it's a general problem so I was hoping some1 could help me out on Zilvia too...
I posted on SupraForums about my problem. Please check it out and reply here with any advice, if any.
My Supra is Pissing Me Off...
I'm AAAMK3 on SF...
-John
93 240SX FOR SALE!!!!!
AAA240SX is offline   Reply With Quote
Old 09-02-2004, 12:06 PM   #2
BobbyBoy
BobbyBoy's Avatar
BobbyBoy is making a name for him/her selfBobbyBoy is making a name for him/her self
Send a message via AIM to BobbyBoy
I saw the pic that sucks.....not as bad as my car though, I have 4 of the 8 exhaust manifold studs on my SR broken off into the head, and they are sunk in, not protruding outward like yours. I have no idea what to do either
BobbyBoy is offline   Reply With Quote
Old 09-02-2004, 12:08 PM   #3
msaskin
msaskin is an unknown quantity at this point
Send a message via AIM to msaskin
Uhh, go get a set of bolt extractors/ez-outs at sears/autozone/store of your choice and go to town.
It's a real simple fix...what's so hard about it?
~matt
it's not turbo lag...it's foreplay
'01 Ford Excursion Limited.
Powerstroke Diesel
Coming in spring: ???
msaskin is offline   Reply With Quote
Old 09-02-2004, 12:14 PM   #4
element240
element240's Avatar
element240 is an unknown quantity at this point
Send a message via AIM to element240
i was in a similar situation earlier.
hmm someone already suggested a good idea on that page, weld a nut on it.
or heat up the area around the bolt with a torch and then put some ice on the broken stud/bolt and use vice grips to try to spin it out
element240 is offline   Reply With Quote
Old 09-02-2004, 12:30 PM   #5
AAA240SX
AAA240SX's Avatar
i tried drilling the broken extractor piece out but my bits won't cut through it. Will the "Drill-Outs" be able to cut through the broken piece and pull it out?
-John
Old 09-02-2004, 08:14 PM   #6
SaintlyCharBoy
SaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her self
Send a message via ICQ to SaintlyCharBoy Send a message via AIM to SaintlyCharBoy Send a message via Yahoo to SaintlyCharBoy
if you can't get enough heat with a propane torch try a MAPP gas torch to heat the surrounding metal, hopefully expanding it
i can't really tell how much it sticks out, but sometimes you can dremel a notch and use a screw driver, or dremel 2 sides and use an open end wrench on the stud
welding a nut on the stud sounds like the best (or most likely to work) method
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage
95 base - retired
SaintlyCharBoy is offline   Reply With Quote
Old 09-03-2004, 07:38 AM   #7
Brolewigi
Brolewigi's Avatar
Brolewigi is an unknown quantity at this point
Don't just drill it out and drill a bigger hole, then tap it. If you are going to fix it, do it the right way. Drill the whole out and get a product called Helicoil. They are hardened steel inserts that go inside the damaged thread. What you do is you get the proper pitch/tap kit and it gives you a bigger tap. You drill it, tap it and then screw in the helicoil. Then you screw in the bolt. That is the way you fix it. I had that problem on my exhaust manifold studs on my turbo'd integra. Try that, I did and it worked and it was worth it.
Brolewigi is offline   Reply With Quote
Old 09-03-2004, 10:05 AM   #8
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
Go get a west coast choppers hat and then weld a nut on there to pull it out,,, ever since i got my welder little problems like that have never phased me, it just gives me a reason to "fabricate" some new stuff.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 09-05-2004, 04:04 AM   #9
rps13_fastback
rps13_fastback's Avatar
rps13_fastback can only hope to improve
Send a message via AIM to rps13_fastback
happened to me before with my b18c1. my dad was stupid and drilled it out with a drill bit but made the hole bigger Someone suggested that I use a dremel and make a + on the broken bolt, and then use a phillips head screwdriver to screw it out. sounds like a longshot but it's just a suggestion. good luck mangs
rps13_fastback is offline   Reply With Quote
Old 09-06-2004, 02:27 PM   #10
AAA240SX
AAA240SX's Avatar
i got this bitch out...
just an update for anyone that has this problem in the future. instead of welding, screwing, drilling, blah...i just went to the hardware store. look for pliers that have sharp ends on them, not the ones with teeth like grooves. it allowed me to bite into the metal and rotate it out. i included a pic of the tool...thanks for the ideas guys!
-John
