Old 11-17-2015, 08:49 PM   #1
wesismyhero
wesismyhero is an unknown quantity at this point
sr20det has zero power, I need advice.
So I recently got my project car running. When I got it it was a mess, half assed and with a bunch of random parts laying around. I frankensteined everything together and finally got it running. It will idle perfectly all day long at 900 rpm once it warms up. When I try to drive it down the road, it has zero power, barely enough to move when floored. In neutral it will rev to between 4500 and 5000. I have changed the MAF, o2 sensor, knock sensor, plugs (NGK BKR6E) set timing, checked voltage on tps, checked compression (165-175 on all), checked fuel pressure,basically everything but a new ecu. Does anyone have any ideas?
Mods to the car are
Freddy intake manifold
Sard fuel rail and 550cc injectors
Aem fuel pump
FMIC
Fujita intake
Isis turbo manifold and fuel pressure regulator
Chase bay's fuel lines
Brian Brower 264 cams
TRust 3 inch downpipe
wesismyhero is offline   Reply With Quote
