Old 02-26-2016, 02:52 AM   #1
NoFlex
NoFlex is an unknown quantity at this point
Turbo oil feed fitting not sitting flush
Hello,
I have an s15 garrett bb turbo, the oil restrictor does not fit flush, i want to make sure it wont leak. It seems to have a decent amount of thread engagement.
NoFlex is offline   Reply With Quote
Old 02-26-2016, 08:39 AM   #2
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
HOLY MEGA-ZOOM bat-man!!!
Have you tried looking for another shorter restrictor? Another option is to check with your turbo manufacturer to see if you can use a type of thread sealer in there.
SoundEfx is offline   Reply With Quote
Old 02-26-2016, 08:50 AM   #3
jedi03
They are supposed to have crush washer in there...is there something blocking it?
Old 02-26-2016, 09:19 AM   #4
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
It should be fine if you use some thread locker on it. My oil feed restrictor sits the same way on my t25 and it doesn't leak. Is that a P2M restrictor? I had one and it got stripped when I tried to thread it into my s15 t28. I need to clean up the threads.
w0nderbr3ad is offline   Reply With Quote
Old 02-26-2016, 10:36 AM   #5
NoFlex
Yeah it is a p2m restrictor. Literally the only restrictor I could find that is -3an. There is a tube inside the that prevents the restrictor from being fastened any more than this. So im assuming its probably going to leak? Sorry for the resolution.
Old 02-26-2016, 10:48 AM   #6
w0nderbr3ad
Trader Rating: (50)
The tube inside is another oil restrictor pin, but as long as you have the P2M fitting sealed with sealant, it shouldn't leak.
Old 02-26-2016, 10:57 AM   #7
derass
My restrictor was also too long. It's supposed to use a crush washer but doesn't thread in far enough to create the seal. However, it doesn't leak. I thought that was strange since they are straight threads and not tapered. It must be pressed up against the pin posted above hard enough to seal.
Old 02-26-2016, 11:15 AM   #8
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
The fitting in an Inverted Flare, (Think Brake line fittings) there is no need to a washer or sealant. The flare is the seal.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 02-26-2016, 11:56 AM   #9
NoFlex
So youre saying that i should be fine without any sealant? And i shouldnt torque it too hard to strip the threads?
Old 02-26-2016, 11:56 AM   #10
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
As long as your threads have full engagement and are the correct pitch you wont have an issue, that piece looks fairly generic so it probably wont sit perfectly into the turbine housing.
[email protected]
hanzbrady is offline   Reply With Quote
Old 02-26-2016, 12:04 PM   #11
derass
Originally Posted by NoFlex View Post
So you[']re saying that [I] should be fine without any sealant?
Originally Posted by derass View Post
My restrictor was also too long... However, it doesn't leak.
Did you read either of our posts?
Old 02-26-2016, 07:44 PM   #12
NoFlex
Yeah, just making sure. Dont want to use sealant if i dont have to
Old 02-26-2016, 07:55 PM   #13
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
If you want to be 100% sure, take the fitting back off, look inside the opening and you should see a cone protruding out like a pyramid. Then on the fitting, you should see a convex cone. If you see both of those, then it's inverted flare and you're set. German Gudentite torque should be enough to hold the seal. Inverted flare seals on the flare, not the threads so putting anything on threads won't help.
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 02-27-2016, 11:13 AM   #14
NoFlex
Here's what the bottom looks like, not sure if its an inverted flare
Old 02-27-2016, 05:14 PM   #15
phase2
phase2's Avatar
phase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of light
Prior post is correct no washer or sealant is needed since the fitting creates a flared seal with the turbo. Once you hand tightened the bolt where you felt the restrictor is bottoming out against the the turbo just hand torque it a bit more and it will be tight. The other thing to look for is when you tighten the turbo oil line to the same fitting make sure you double wrench it so that you don't over torque the restrictor and strip the fitting.
Sent from my SM-G928T using Tapatalk
Business Hours: Mon-Fri 10am-6pm (Pacific)
email: [email protected]
http://www.phase2motortrend.com
phase2 is offline   Reply With Quote
Old 03-14-2016, 01:17 AM   #16
NoFlex
ended up not leaking! works very well, highly recommended fitting
Old 03-17-2016, 05:12 AM   #17
phase2
phase2's Avatar
That is good to hear.
