Old 03-12-2016, 06:46 AM   #1
OutToWinPAHC
OutToWinPAHC's Avatar
OutToWinPAHC is an unknown quantity at this point
Send a message via AIM to OutToWinPAHC
Fully built RB25DET partial partout, Tomei, Kelford, Greddy, AEM Series 2
RB25DET full built partial part out.
Philadelphia, Pennsylvania any shipping and paypal is extra
Going to be parting my motor. Series 2 RB25DET
Some pics are before the build, some are during other are after.
Long Block firm at $3500 will include OEM rear timing and rocker covers. Engine built by BMS racing engines in Plymouth meeting PA... I WILL NOT PART THE LONG BLOCK.
(Bore 86.5mmx stroke 71.7mm total 2527cc)
-ARP Head Studs, 2000 series rod bolts
-Cosworth 87mmx1.5mm headgasket
-Wiseco Pistons .20 over 8.4:1
-Eagle H beam Rods
-Power Enterprise Timing belt
-Tomei cam gears
-VCT removed
-Nitto crank collar
-n1 oil pump with spool import gears
-Kelford 272 9.35mm non vtc cams
-Supertech valvespring / retainer kit
-Supertech lifters
-OEM gasket set minus the head and manifolds
- 10AN turbo drain block fitting
-Raw oil fitting (oil heater removed).
-ARP flywheel bolts
$1200 for all
-Greddy Intake Manifold, ported and gasket matched, chrome plated with rainbow sparkle clear powder
-Q45 83mm Throttle body
-Sentra IACV
-Bosch 850cc injectors
-Top Feed rail - 6AN
Can separate fuel rail and intake (new o rings, new rail hardware, new injector cups too) $550.00 Solo, intake Solo 850.
$1150
-AEM EMS Series 2 Standalone with box, under warrenty will include CAS with AEM wheel.
$600
-Custom Top Turbo Manifold / downpipe, ceramic coated open scroll T3 schedule 40 stianless. Dp is RHD only but available. Tial 38MM v band flange
$600
All timing / valve covers with PNP / neo LQ4 coil packs
OutToWinPAHC is offline   Reply With Quote
Old 03-12-2016, 09:30 AM   #2
richierichness
richierichness is an unknown quantity at this point
What turbo and how much boost/power were you making? Compression numbers?
richierichness is offline   Reply With Quote
Old 03-12-2016, 09:39 AM   #3
RB25GUY
RB25GUY's Avatar
RB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to all
5858 dbb and i believe it made 500whp on 18 psi something like that
Originally Posted by smellslikecurry View Post
Its not like you're putting a safc in a fucking Tesla.
RB25GUY is offline   Reply With Quote
Old 03-12-2016, 09:43 AM   #4
gostrider
gostrider is an unknown quantity at this point
nice i want some
240 with illegal engine mod.
gostrider is offline   Reply With Quote
Old 03-12-2016, 02:34 PM   #5
OutToWinPAHC
Keeping the snail for another car, mase 512whp at 90% injector duty.
Injectors/rail sold
Old 03-17-2016, 09:50 PM   #6
mando240
mando240 is an unknown quantity at this point
A little more info on the manifold, can you get a pic up of just the mani.
instagram.com/NissansFinest
mando240 is offline   Reply With Quote
Old 03-18-2016, 09:02 PM   #7
Big Daddy 18det
Big Daddy 18det's Avatar
Big Daddy 18det is an unknown quantity at this point
RB 1995 r33
Question the $600.00 is the for the exhaust manifold turbo and all ?
-Eagle H beam Rods
-Tomei cam gears
-VCT removed
-Nitto crank collar
-Supertech lifters
-ARP flywheel bolts
$1200 for all
-Sentra IACV
$1150
$600
-Custom Top Turbo Manifold / downpipe, ceramic coated open scroll T3 schedule 40 stianless. Dp is RHD only. Tial 38MM v band
$600
All timing / valve covers with PNP / neo LQ4 coil packs[/QUOTE]
Big Daddy 18det is offline   Reply With Quote
Old 03-22-2016, 01:36 PM   #8
OutToWinPAHC
a 600 dollar manifold, gets you a manifold for 600, not 2k in extras
Old 03-22-2016, 01:44 PM   #9
OutToWinPAHC
Old 03-22-2016, 01:51 PM   #10
gostrider
sucks its only RHD
Old 03-22-2016, 03:34 PM   #11
OutToWinPAHC
manifold isnt, down-pipe is but down-pipe is sold separately tho
