Old 03-31-2016, 12:09 PM   #1
jlmillionaire
jlmillionaire's Avatar
jlmillionaire is an unknown quantity at this point
s14 Timing question
Hey guys I'm about to do a head removal, I rotated the harmonic balancer a ton of times I cannot get the timing marks to line up . Here's the closet I got it picture will show what I'm talking about. I just want to make sure I'm good to go before I remove the head thanks. #1 piston is at tdc and the lobes on the cams are opposite of each other and harmonic balancer is on the second mark.
jlmillionaire is offline   Reply With Quote
Old 03-31-2016, 12:47 PM   #2
jlmillionaire
Old 03-31-2016, 01:14 PM   #3
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
Assuming your timing was correct before, its fine
I remember a thread about trying to see the darker links line up with the cam gear dots after aligning them up the first time. It takes a shit ton of rotations.
Jorgs_7 is offline   Reply With Quote
Old 03-31-2016, 01:56 PM   #4
cotbu
cotbu's Avatar
In all honesty it doesn't matter now since you are removing the head but its good practice.
My bad two post kinda blended together
Old 03-31-2016, 02:07 PM   #5
jlmillionaire
Thanks guys I just moved forward just removed the cam caps thanks for input as always !!!
Old 03-31-2016, 05:40 PM   #6
Kingtal0n
Kingtal0n's Avatar
Are you talking about the silver links?
Ignore them. I've seen them line up maybe once when I first got my first sr20 I was obsessed with them. But they don't really matter as you can simply go by lobes and the number of links between dots etc
