Old 09-17-2016, 03:13 AM   #1
donsonpham
donsonpham is an unknown quantity at this point
Sound of grinding/whirring when clutch in
After my 5 speed swap I've been having this weird sound coming from down under. It sounds like grinding or so when clutch pedal pressed. The slave is properly bled, I greased the Input shaft, but not sure what was going on. I later replaced the TOB during my second tranny swap due to the previous one being pulled from pick n pull (a hit or miss). Got my second tranny up now and with a NEW TOB and still have that same noise. Rev match and it still makes the same noise. My Short shifter is also stiff but doesn't seem like the likely cause. Someone help a brotha out.
-dp
donsonpham is offline   Reply With Quote
grinding, throwout bearing
