Old 07-09-2016, 03:50 PM   #1
Climb385
Climb385 is an unknown quantity at this point
Sr20 part out! A lot of aftermarket parts
All prices are best offer
Redtop sr unopened stock motor,
Megan turbo mani $100
Isr rs3871 turbo $250
Hks Adjustable wastegate (12lbs) $80
Nistune ecu (stock flash by AVP in Tennessee) comes with consult cable $old
Isis turbo elbow/downpipe $160
S14 sr water neck with coolant feed and tapped 1/8" for extra coolant sensor (currently plugged off) $85
Steel braided coolant and oil feed lines free with purchase of turbo
S14 oem turbo oil return (brand new) free with purchase of turbo
Heater core hoses modified using short NAPA coolant hoses (no behind head bs)
S13 sr to S13 Wiring specialties harness $200
Isis rad with shroud and fans $260
Oem upper and lower coolant hoses $50
Isis intercooler with greddy flange $300 plus ship
Exedy 3 puck clutch $300
Resurfaced oem flywheel
Redtop ac bracket with codyace S13 ka swap brackets $200
When I swapped motor in I replaced the rear main seal, valve cover gasket, plugs, injectors, head to turbo mani studs/nuts and 7 layer gasket, mani to turbo gasket and studs/nuts with locking tabs, 5 bolt turbo to dp gasket and studs/nuts, new tps, new O2 sensor (fat), coolant heater core hoses, S14 oil return set up bought brand new,
Car developed a misfire, replaced coil, plug, coil harness, and moved fuel injector, still missing in cylinder 4, I'm done with sr's going rb25,
Update Motor runs. No misfire, but needs a lifter, rocker arm fell off intake cylinder 4, put it back on and it has a tap, but runs
Sold
Ecu
Harness
Thank you Cory
(412) 480 1551
Climb385 is offline   Reply With Quote
Old 07-09-2016, 04:49 PM   #2
Your_Mom
Your_Mom is an unknown quantity at this point
Hey Cory, I'm in greensburg, I'm interested in the block, don't need the head or anything else. If interested in separating let me know.
Your_Mom is offline   Reply With Quote
Old 07-09-2016, 04:56 PM   #3
Climb385
Selling motor as a long block
Old 07-09-2016, 05:20 PM   #4
Your_Mom
what do you want for the long block?
Old 07-09-2016, 05:41 PM   #5
Climb385
700 obo for the motor valve cover to oil pan
Old 07-10-2016, 10:05 AM   #6
Climb385
Old 07-11-2016, 10:24 AM   #7
Climb385
Bump it to the top
Old 07-15-2016, 12:33 AM   #8
SDs13
SDs13 is an unknown quantity at this point
How much for the heater core houses to 92139
Sent from my SM-N910V using Tapatalk
SDs13 is offline   Reply With Quote
Old 07-18-2016, 05:31 PM   #9
Climb385
bump motor is out of car some buy it all for 1200
Old 07-25-2016, 10:14 PM   #10
Climb385
bump it to the top
Old 08-03-2016, 10:40 PM   #11
Climb385
turbo, downpipe and elbow, and mint trans sold
Old 09-03-2016, 09:38 PM   #12
Climb385
just few things left pm me
Old 11-23-2016, 04:03 PM   #13
skyline084
skyline084 is an unknown quantity at this point
Still have the motor?
skyline084 is offline   Reply With Quote
Old 11-26-2016, 03:43 AM   #14
Adafg67
Adafg67 is an unknown quantity at this point
Is the down pipe/ outlet still for sale?
Adafg67 is offline   Reply With Quote
Old 11-26-2016, 02:05 PM   #15
rodm773
rodm773's Avatar
rodm773 is an unknown quantity at this point
Alternator?
Sent from my SM-G935T using Tapatalk
rodm773 is offline   Reply With Quote
Old 11-26-2016, 02:27 PM   #16
asianleful
asianleful is an unknown quantity at this point
intercooler and piping still available?
asianleful is offline   Reply With Quote
Old 11-26-2016, 03:34 PM   #17
Climb385
Only think left is intercooler kit, rad with fans, ps pump and hose,
