Old 10-09-2004, 09:47 PM   #1
TwiztedParallel
TwiztedParallel is an unknown quantity at this point
Send a message via AIM to TwiztedParallel
Unhappy Another 'problem starting' thread...
Ok, Ive been doing tons of work to the suspension and brake components for my S13 and took out the battery while I was doing the work. I also took off the air intake piping. So when Im done with all my work I put the battery on along with the intake pipe, car starts fine, alittle hesitation, but only a second or so (the usual for me). Run the car for 3-5 minutes and turn it off. I move the tension pulley to the A/C and try to start the car again, starter is running, and I can smell fuel also. But it just wont start. I realise that I might not be getting enough/any air so I ask my friend to try and turn it over, and while he did that I moved the throttle cable to open the butterfly valve on the throttle body, starts up alright.. really rough so I hold the cable untill it warms up and let it go, idle is dead on at about 800rpm. I let the car idle for about 10-15minutes and turn it off, try to start the car again and nothing.
I know it has to do with the air somehow, but I dunno what it can be. I know the idle is ok because its actually above the 750 mark on the tach. Im guessing a sensor maybe somewhere? I plugged the two rubber hoses up pretty good leading to the intake pipe by the throttle body. Anywhos, anyone have an Idea of what it can be?
Thanks a ton!
TwiztedParallel is offline   Reply With Quote
Old 10-09-2004, 10:09 PM   #2
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
remove the tension to ac, i dont know why the hell that would have anything to do, but u siad it started fine otherwise. see what happens.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 10-09-2004, 10:58 PM   #3
kandyflip445
kandyflip445's Avatar
If you smell fuel pull your spark plugs and check if they cylinder is flooded.
My 240 vBgarage
Old 10-09-2004, 11:30 PM   #4
TwiztedParallel
I have since put the tension pulley back in its original posistion and the cylinder isnt flooded because I can turn on the car and burn off all the fuel.. I can getted started running fine if I use the throttle cable to open the butterfly valve... I just dont wanna do that everytime, and I dont want to rig it ghetto either..
Anyone else have an Idea? Maybe a sensor or something???
Thanks for the help in advance.
