Old 12-18-2018, 09:30 AM   #1
Omar S
Omar S's Avatar
Omar S is an unknown quantity at this point
Parts parts parts! S13 S14 S15 - R32 / STI
Parts Clean-out
[emoji3502]180sx Hatch / S13 Coupe
$600 - KAAZ 2-Way diff (4.01 final gear
Non-abs housing, S13 diff cover
Fully locking w/ 6 bolt half shafts)
$100 - Solid DIF Subframe Bushings
$170 - ISR PRO Rear upper control arms (bnib)
$140 - ISR PRO rear toe arms (bnib)
$100 - GodSpeed front lower control arms
$80 - RHD Door Panels (Brown)
$200 - RHD Blk Dash/console/bezel (cracks)
$200 - DMAX S13/S15 hard tierods D1 SPEC
$100 - Teal front frame brace
$200 - Multi-vented fiberglass coupe windowlouvers
$1000 - SF carbon fiber wing (chassis mount)
$60 - s13 coupe tail lights (clean)
$80 - HICAS s13 rear subframe
$80 - Non Hicas s13 rear subframe
$80 - Abs s13 driveshaft
$180 - s13 5 spd trans
$100 - s13 open diff
$100 - s13 manual doors
$100 - s13 trunk (clean)
$80 - s13 trunk (less clean)
$50 - s13 dash (some cracks)
$150 - 4x114 s13 oem wheels w new tires
$50 all 4 abs s13 calipers
$100 - complete s13 ka24de intake mani w injectors
$100 - S13 chuki front bumper complete
[emoji3502]S14 Zenki / Kouki
$160 - ISR PRO Rear upper control arms
$50 - Ebay KA Headers
$300 - Front Street Faction bash bar
$300 - Rear Street Faction bash bar
$200 - Navan style zenki skirts (black)
$45 - SF S14 Angled 60mm Gauge Bezel
$10 - Oem steering wheel w/o airbag
$240 - Brand new Origin type 4 75mm rear overs never mounted
[emoji3502]Silvia S15
$150 - Fog lights + switch
$200 - Hippo Sleek front bumper
$80 - Black door panels
[emoji3502]Other Parts / Misc.
$1400 - 2018 Subaru STI Wheels + brand new tires
$200 - 2018 Subaru STI OEM Springs
$300 - R32 GTST Calipers set (aluminum)
$200 - Front Z32/S14 pair (cast iron)
$1200 - s13 sr20det with clutch/flywheel/trans/ short shifter/ driveshaft/ 550 cc injectors/ rs enthalpy tuned ecu (550 cc, z32 maf, gt2871r)/ freddy intake/ all accessories/ all internals included.
Motor had bad piston rings. Currently disassembled
Missing valve cover, oil pan, turbo n turbo mani
May have a t25/stock mani lined up if you’re interested as well as a valve cover
[emoji3502] Notes
[emoji328] I have photos, just ask below.
[emoji3544] I can ‘hold’ if you paypal half down.
[emoji3544] Shipping is a seperate fee. Pm Zipcode.
91 s13 coupe MINT stock
Omar S is offline   Reply With Quote
