Old 02-13-2017, 01:16 PM   #1
mλx_s13
mλx_s13 is an unknown quantity at this point
350Z half shaft in 240?
Hey,
Does anybody have any experience with using 350z axles in a s13 chassis. I'll be swapping to a 5bolt Z32 NA differential.
Thank you,
Michael
mλx_s13 is offline   Reply With Quote
Old 02-15-2017, 09:30 AM   #2
mλx_s13
Still trying to figure this out..
Old 02-15-2017, 04:29 PM   #3
JM216S14
JM216S14's Avatar
JM216S14 is on a distinguished road
There are 0 threads out there on this.
JM216S14 is offline   Reply With Quote
Old 02-15-2017, 05:49 PM   #4
mλx_s13
Hopefully that's not sarcastic.. new here.
Saw this, sparked an idea..
http://zilvia.net/f/showthread.php?t=640449
Old 02-20-2017, 12:08 PM   #5
mλx_s13
BUMp......
Old 02-20-2017, 07:55 PM   #6
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond repute
Feedback Score: 18 reviews
Well, 350Z axles have 6 bolts, so you'll have to figure out if the stubs fit the z32 diff.
LoSt180 is offline   Reply With Quote
Old 02-21-2017, 07:17 AM   #7
TheRealSy90
TheRealSy90's Avatar
The 6 bolt pattern is the same as 6 bolt Z/Q stub shafts.
The outer splines fit s13 hubs.
Figure it out.
(it'll work)
Such a good signature.
Old 02-21-2017, 06:14 PM   #8
mλx_s13
Figure it out.
(it'll work)
Awesome! I'm going to order a set then. So the length won't be an issue if I'm at stock ride height though?
Thanks,
Michael
Old 02-21-2017, 07:51 PM   #9
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Thanks,
Michael
According to that thread the length is fine, you just need to matching 6 bolts stubs in the differential. Z32 is 5 bolts.
Old 02-22-2017, 12:52 PM   #10
mλx_s13
I'm not sure how I missed that..
Old 02-22-2017, 01:42 PM   #11
S-Verteen
S-Verteen is an unknown quantity at this point
I cut the sub frame and used the 350z diff also since it has a cd009 trans to keep gearing proportionate extended rear lower control arms 3/4 of an inch if i can recall correctly the diff is half inch wider total id guess the diff your using would only need half inch width per side increase for the axle length.
S-Verteen is offline   Reply With Quote
Old 03-01-2017, 01:35 PM   #12
mλx_s13
The last question, If I found a J30 6 bolt with ABS, Is it possibly to put the J30 output flanges into the Z32 NA diff?
Should fit considering they're both R200?
Thanks for the help guys,
Michael
Old 03-01-2017, 02:02 PM   #13
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
Swap in a S14 subframe, then buy maverick motorsports 350z/g35 conversion bushings so you can bolt the diff in without modification. That way you get the diff and axles that match.
DJPimpFlex is offline   Reply With Quote
Old 03-02-2017, 07:24 AM   #14
mλx_s13
While that sounds like a good idea, I just found the J30 diff at my local pull a part..
And I dont mind pulling the diff apart to fit it.
Old 03-02-2017, 09:37 AM   #15
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
That's a different bolt pattern, a simple google search would of answered that for you.
I have a set of brand new Maverick Motorsports axle adapters with hardware for sale that i ended up not being able to use. (Twin Turbo Z32 are slightly different) let me know if you're interested.
Review Thread
bardabe is offline   Reply With Quote
Old 03-02-2017, 12:13 PM   #16
mλx_s13
Originally Posted by bardabe View Post
That's a different bolt pattern, a simple google search would have answered that for you.
Last of the last, ugh:
Couldn't I just put the j30 LSD/ carrier into my open diff, provided I swap the ring gear on the carrier and also change the output shafts? Essentially like installing a new aftermarket differential...
If this doesn't work I guess I'll just have to go to axle adapters
