Old 03-20-2017, 01:32 AM   #1
240-mike
240-mike is an unknown quantity at this point
Rb25 spark plug issue
Okay so I've looked through many different threads and can't find a straight forward answer to my problem so please don't give me the bs about starting another thread. So I can't figure out what to gap my plugs to, I have fmic full exhaust upgraded fuel pump stock Ecu stock intake etc. I was running on 10psi and every time I'd get into high boost it cut out so I figured I needed colder plugs along with regapping them, I've Gapped them several times with no luck, everytime I give it gas it won't rev past 3 grand and just falls on its face. Any helps appreciated, oh and the plugs I went with were the NGK bkr7es I believe, thanks again.
240-mike is offline   Reply With Quote
Old 03-26-2017, 02:50 PM   #2
240-mike
Got a new maf sensor didn't solve the issue but now it'll rev to 4K and sometimes even 5k
Still falls on its face and won't build boost
Old 03-26-2017, 03:08 PM   #3
KAT-PWR
KAT-PWR's Avatar
KAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really nice
Have you boost leak tested
MRP Manufacturing
KAT-PWR is offline   Reply With Quote
Old 03-27-2017, 06:46 AM   #4
Loufig
Loufig is making his/her stupidity well-knownLoufig is making his/her stupidity well-knownLoufig is making his/her stupidity well-knownLoufig is making his/her stupidity well-known
Boost leak test that would be a waste of time and surely has nothing to do with not being able to boost...
Loufig is offline   Reply With Quote
Old 03-27-2017, 09:27 AM   #5
socalbmxr06
socalbmxr06 is an unknown quantity at this point
Definitely check for a boost/ vacuum leak. Spark plug gap on the RB25 should be .028 to prevent spark blow out. RB25 oem coil packs don't pack much of a punch.
If there are no leaks and plugs are good I would check injectors to make sure they aren't leaking.
socalbmxr06 is offline   Reply With Quote
help me, rb25, spark plug
