![]() A little history on the motor.
I brought the motor from a guy named Mike Moretti on the JZ groups. It was his spare motor Nothing wrong with the motor I took the turbos off because I was going single turbo. Basically what I was going to do was refresh the whole motor before swapping it in and buying a harness and standalone but I found a dd I want so I've decided to put this up for sale. NO HARNESS OR ECU -1JZ short block -1JZ front sump oil Pan -1JZ fuse fabrication T3 Turbo Manifold -2JZ water pumps -2JZ Oil pump -NST Alt, WP, PS, & Tensioner Pulley -Ross Tuffbond Metal Jacket Crank Pulley -1JZ Alternator -1JZ starter -2 1JZ Cam Seals (Non-vvti) -1JZ Timing belt idler pulley -1JZ Front main seal -1JZ Rear main seal -1JZ Thermonstat -2 1JZ timing belt guide -2 1JZ timing belt hydraulic tensioner -1JZ valve covers -1JZ intake manifold -Tomei cam gears Cam, crank, and rear main seals were done, oil pan was resealed with new bolts $3000 obo Located in orlando fl prefer a local sale ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
