10-19-2004, 01:30 PM | #1 |
harness??
can i use a 89 ka harness to wire up to the sr one. Its going into a 91 s13. i cant go without a car. any info would be appreciated.
thank you david |
10-19-2004, 01:50 PM | #2 |
alls you need from your ka harness is your lower battery harness, that includes battery cable alternator ground speed sensor plug is on there and a couple fuse plugs, send your main engine harness out to heavythrottle they wire everything up and all you do is plug it in when you get it back done, call it a day. good luck.
chris
chris's sr |
10-19-2004, 04:02 PM | #3 | |
Sending it to HT doesn't solve the fact that neither KA harness will have all the correct plugs, IE ignitor, coilpacks, etc.
10-19-2004, 04:04 PM | #4 |
He said "can i use a 89 ka harness to wire up to the sr one." That implies that modifying the SOHC harness to teh SR harness...
http://nissanperformancemag.com/march04/240sr/
Keep it Classy |
10-19-2004, 07:14 PM | #6 |
Actually, the other way around, I believe. You use the SR harness, and can use some wires from the KA harness to extend SR harness wires. You cannot run a SR with a KA harness, period.
10-19-2004, 09:10 PM | #7 | |
