Old 08-27-2018, 04:29 AM   #1
fastlanexxx
fastlanexxx is an unknown quantity at this point
new SR22DET Stroker Engine for sale
Due to a project change for sale
All parts were new, and now have about 1000km retract
No high loads.
Costs over 13.000 €
SR22DET specs
Washed and runways drilled and hired. Crankshaft main bearing lane equipped with reinforced bearing blocks and re-drilled and honed. The crankshaft was dynamically balanced together with the flywheel, the pressure basket and the pulley. The connecting rods were provided with additional grooves for best oil circulation of the piston pin, even at the highest speeds. Cylinder head planned. By hand, all ducts for exhaust and exhaust gas are enlarged and smoothed, and webs sharpened, etc. All other corners and edges of water channels, etc. have been improved. Valve seats milled and re-ground. All transitions and edges of intake manifold, throttle, exhaust manifold and cylinder head have been eliminated for optimal flow - everything has been completed, sealed. All sensors and connections have been incorporated, as well as intake air temperature sensor, pressure sensor, water temperature sensor.
Brian Crower (BC) Stroker Kit full Spec 91mm full forging shaft (later rebalanced for highest speed demands)
CP piston 87 mm 8.5: 1 with upgrade Piston pin (thicker wall thickness) for more load capacity
BC connecting rods and custom connecting rod bolts (the Arp hold 200,000psi, the screws used here 290,000)
ACL Race main bearing cups
ACL Race connecting rod bearings
ARP main bearing studs / screws
Arp head stud / screws
BC Camshafts 272 ° inlet & outlet with max. 12.55mm stroke
BC valve seats / guides
BC larger inlet and outlet valves
BC reinforced valve keys Fits the valves for more load capacity
Supertech gaskets for the valve seats
BC reinforced valve springs
BC Titan valve spring plate
Cometic cylinder head gasket
large oil pan
Oil pump original
Water pump original
Timing chain set complete original
Engine gasket original
Lima
Aluminum pulleys
Nismo oil lid
Motor mount / servo and alternator holder, water intake manifolds were powdered black
Valve cover orange powder coated.
The engine is sold with the attachments shown in the pictures.
What is missing are manifold / turbo / intake manifold / ignition coils
PRICE for the Engine 6.999€
Also the intake manifold on the last picture can be purchased
Handcrafted and only custom made suction bridge from SAR Turbotechnik with large plenum and optimized flow
1000ccm Bosch Injector
Injector bar Custom (larger passage)
Idle controller
Accufab throttle with potentiometer
fastlanexxx is offline   Reply With Quote
Old 08-27-2018, 10:36 AM   #2
astonmartian
astonmartian is an unknown quantity at this point
Msglength.
astonmartian is offline   Reply With Quote
