Old 08-07-2018, 11:19 AM   #1
Jakes32guitar
Jakes32guitar is an unknown quantity at this point
Cammed LS6 T56 Swapped S14 with S15 front clip $11,500
Selling my 240, was a project car over winter for me and my wife and I are trying to get a down payment together for a lake lot so selling a few things. This car is a ton of fun and runs and drives great as is. Many good quality parts were used and it is very fast, this is not a drift car, I wanted a street/strip car. The engine is a LS1 that I rebuilt with a ground crank and new rod/main and cam bearings. It has 243 heads and a LS6 intake manifold making it the same as a LS6. I installed a 227/236 duration at .050 and 600/600 lift cam with Pac 1218 valve springs as well as 42lb injectors. The T56 had 95k miles on it and the clutch was replaced with a LS7 clutch and flywheel and a new slave. The swap parts are Hooker mounts and headers, wiring specialties plug and play harness, custom 1000hp rated drive shaft, Sikky power steering lines, GTO oil pan and custom fuel lines with a Walboro 450 in tank pump. The ecu was custom tuned and it has never been on a dyno currently but similar builds have been making 420-430hp at the wheels so it should be around there. The interior is mostly there and it runs and drives good. Just needs your finishing touches to make it what you want! I am located in Zimmerman Minnesota.
new ad https://minneapolis.craigslist.org/c...679994374.html
Jakes32guitar is offline   Reply With Quote
