![]() Join Date: Oct 2007
s14 kouki sr20vet / cd009
follow me
Facebook : Pierre-Olivier Belisle insta : blkreapers14 Built info head: p11 head machined for 1/2 studs p12 cams Yashio Factory p12 valve cover Mazworx shimless valves brain crower cam gears Kelford beehive springs Taarks hallsensor kit Taarks single vvl conversion kit Mazworx headgasket Hypertune intake Bosch 82mm dbw throttle body bottom end: s14 block sleeved with Darton sleeves + gtir main bearing mod Mazworx billet main cap with 1/2 main and head studs JE ultra serie sr20det pistons 87mm 10.5:1 (will work with ve swap) Wiseco Boostline rods det crank King gtir main bearing new timing chaine kit new sr20ve p12 oil pump taarks water pump delete moroso oil pan taarks oil filter relocation kit taarks power steering relocation kit taarks timing mark relocation new seals everywhere ATI crank pulley Drivetrain: Comp Cutch tripple plate g37 transmission (with z34 rear tail section with gear position sensor) Mazworx sr to vq Bellhousing GKtech z33 shifter kit 4:10 gear z33 axles Weir performance z33 chromoly conversion hub with spool diff Cooling: c&r custom rad Electric water pump an fitting welded for rad hose swirl pot custom made oil cooler and power steering cooler hot side: Doc race sr20ve manifold with v-band flange and mvr waste gate flange (i provided a sr20ve flange to them ... flange from taarks) custom down pipe fuel: Id ? I will run e85 electronic: Motec m130 (gpr , stage 2 loging) Motec pdm15 with keypad Motec c127 dash Racegrade tc8 egt box exterior: Superdoof body kit Bn Sports type2 Hood Origin Labo type 3 front and rear fenders dmax roof wing Brake: up front : z32 calipers Hawk hp+ pads stoptech z33 rotors z1motorsport conversion bracket in the back : z32 calipers Hawk hps pads (regular brakes) project MU d-spec pads (hydro hand-brake) z32 stoptech rotors HGK billet Hydro Handbrake suspension and steering : Sparco 2 spokes steering wheel Custom steering column fortune auto 500 v5 / swift spring (7k/6k) Front: Gktech top plate Gktech front v3 knuckle Gktech cromoly flca Gktech front swaybar Gktech inner /outter tierods rack moved forward 35mm with custom c-clamp BinkIndustries rack spacers Rear: Gktech rear Knuckle Gktech rlca Gktech suspension arms Gktech subftame riser Gktech subframe brace kit SPL solid diff bushing wheels GAIA MMX III 2x 18x9.5 and 4x 18x10.5 Last edited by rbs14kouki; 06-07-2021 at 09:42 AM.. |
