Old 06-04-2019, 07:49 PM   #1
EnnEssEnnKAT
EnnEssEnnKAT's Avatar
EnnEssEnnKAT can only hope to improve
Used Swift Springs 8/6 and CST coilovers parts
Selling a set of CST zero-1 coilovers with 60mm swift springs 8 kg (F) and 6 kg (R).
Contact: PM
Price: $150 + shipping
The front coilovers were disassembled but could be easily reassembled, pillowball top hats with hardware all in good shape, bottom dampening adjustments are gone. I believe one of the front shocks is blown so I started disassembly. The rears have a busted lower bushing insert/collar (pictured) due to it seizing on the stud, but the dampening adjustments work good just a little dirty.
Swift Spring Dimensions
Front
ID 60 mm
OD 80 mm
Height 205 mm (uncompressed)
Rear
ID/OD same as front
Height 230 mm (partially compressed, still mounted)
more pictures:
https://1drv.ms/u/s!Am1HiCLFo3Gsl-o1...vwy_g?e=Z8Vk3S
EnnEssEnnKAT is offline   Reply With Quote
Old 06-05-2019, 08:00 AM   #2
tuzzio
tuzzio's Avatar
Would you sell the swifts separate? Wonder if they'd fit on my BCs...
Old 06-05-2019, 10:20 AM   #3
EnnEssEnnKAT
Yes I can give you the spring height measurements if that will help. ID is 60 mm - lmk
Old 06-20-2019, 08:12 PM   #4
EnnEssEnnKAT
Bump everything still for sale OBO
Old 06-20-2019, 10:37 PM   #5
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
Any measurements on those springs??
Wondering if they would fit my fortune auto
andisan is offline   Reply With Quote
Old 06-27-2019, 05:22 AM   #6
Fitelite240!!
Fitelite240!! is making his/her stupidity well-knownFitelite240!! is making his/her stupidity well-knownFitelite240!! is making his/her stupidity well-knownFitelite240!! is making his/her stupidity well-known
Clear your inbox I've got another question about the lower spring perches
Fitelite240!! is offline   Reply With Quote
Old 06-27-2019, 09:21 AM   #7
EnnEssEnnKAT
Dimensions added to the first post, let me know if that doesn't get you what you need.
Done, woops.
Old 06-27-2019, 01:42 PM   #8
gills
gills's Avatar
gills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the rough
Interesting...those are inverted struts in the front. Any idea what the piston diameter is on them?
IG: core4motorsports
www.core4motorsports.com
gills is offline   Reply With Quote
Old 06-27-2019, 03:51 PM   #9
slider2828
slider2828's Avatar
BCs are like 63mm... BC's have custom sizing of swifts on their website which I think are gold or something.... 65 is probably closer. The blues in there are 60mm...
Just fyi
Turn and Burn!
Old 06-27-2019, 04:00 PM   #10
Fitelite240!!
Just fyi
Yea, my Neomotorsports coils are 63mm ID. 65mm would fit but it would be iffy.
Funny enough I contacted Neomotorsports and they said the same thing about custom Swift springs from 61-65 mm to sit flush on their bottom collar.
That's what I'm trying to figure out for my helpers. If these bottom perches fit my 60mm helpers, I'll be good and run them.
Otherwise, I'll have to CNC the lower collars about 1mm smaller to fit the spring properly without affecting anythinf.
That's if these collars thread around my coils correctly.
If the OP wants to respond to my last PM. But, #peoplebebusy #igetit
Old 06-27-2019, 05:11 PM   #11
slider2828
slider2828's Avatar
Nah man. 2mm is like two finger nails. Run 65s on those collars.... I ran megan racings, which are also around 63mm or 62mm, with 65 on many track days. dun worry about it.....
Don't mess with the threads.... they are all custom... its a guess on those thread pitches for different manuf.
I also run 65mm 3k helpers on my megans. Also if you are in california, run some needle bearings from summit. But yeah they will work
Turn and Burn!
Old 03-11-2020, 09:27 AM   #12
EnnEssEnnKAT
Sold mods please close
