Old 02-08-2020, 12:47 AM   #1
doridoridori
doridoridori is an unknown quantity at this point
need help, S13 SR20 Redtop No spark
As the title states, I'm having a no spark issue. I'll give a rundown of what happened up until it won't start again.
Long story short my turbo went out so i replaced it with the same turbo just new. S15 T28. After installing the turbo later that night I went out to eat with friends, went downtown and late that night the car just died on me while driving like 5-10mph. Tried to start it again and it cranked but got nothing.
Towed the car home, I ended up buying 2 maf's because I had a maf go bad on me once and it just fell on it's face so I was under the assumption it was that but I was wrong. Tried 2 Z32 Mafs (im running an enthalpy tuned ecu), the first maf i put in the car started up, ran for a few mins then fell on it's face and wouldn't turn on again after.
The next day I put another maf in and it started up but died a minute or so after and would not come back on. I checked all my fuses and non of them are bad. Later that day I figured let me check for spark so i left the coil packs plugged up to their designated connectors, put a screw driver at the end of each coil pack and got no spark at all. I did have a CAS go bad once long time ago so a buddy of mine brought a good CAS off his running car by, stabbed it properly and still nothing. I can smell fuel, the fuel pump primes when i turn key to on position but nothing. I even picked up a good Ignitor from a buddy late tonight and figured well if i have no spark if it isn't the CAS it has to be the ignitor but after swapping the ignitor the car still won't turn on.
Any suggestions?? im starting to assume MAYBE ecu took a crap but i don't have wires all over the place that would cause the ecu to just short out but maybe they can just go bad anyway?
any help would be greatly appreciated I'm stumped at this point.
If I had a dollar for every pet named "nismo" by a nissan owner Id be rich
doridoridori is offline   Reply With Quote
