Injectors not getting power help
Hello zilvia lads, I am once again requesting your support lmao. So i'm having issues getting my injectors to work correctly. I have fuel in the fuel rail and the fuel pump is priming. I took a multimeter to my injector #1 harness cable and i read resistance but when i went to dc It only read 150+ for some reason. This is with the key in the on position. I thought it could be my ignition chip cause it wasn't reading any continuity but that didn't work. I have a feeling it might be my ecu which would suck so hard
#2 | |
![]() Join Date: Feb 2012
Fuel Injector wire should be reading 12 volt while ignition turn on. Check the fuses if working. It can be bad ecu, engine harness, distributor or injector. |
Tags |
injector |
