Old 11-25-2020, 10:11 AM   #1
Silv1401
Silv1401's Avatar
Silv1401 is an unknown quantity at this point
350z rear hub bolt pattern same as Schassis?
Hey, trying to finish up my 6pot/4pot BBK swap on my s14, and I'm looking at parking brake solutions. I can speculate the Z32 drum assembly + r33 cables will work fine, however, I came across a pair of complete rear assemblies for a 370z Nismo, and figured that wouldn't be a bad set up seeing as how I'd get a proper fitting rotor shield with it.
So my question is: does anyone know if the 350z/370z hub bolt pattern lines up on a s14 rear knuckle? I've searched, and the only thread I can find talks about incompatibility of other parts like the axles & dif. It would be a lot cheaper than the z32 setup, oddly enough.
Silv1401 is offline   Reply With Quote
bbk, parking brake, z34 drum brake
