Old 01-02-2005, 01:26 AM   #1
AllenRPS13
AllenRPS13's Avatar
AllenRPS13 is an unknown quantity at this point
s13 Water getting into the trunk... Why?
since it's rainy day in bay area recently, i discover that my trunk was all wet... the water get into the trunk because of heavy rain... do u guys have any idea and tell me why the water can go into the trunk? iare there any leaks? thanks!
~小アレンのリベリオン~
いくせ, 勝負た! 轟こう, オレのKRMS13!!!
オレの得意技!蹴り進入!角度の少ないドリフト!
AllenRPS13 is offline   Reply With Quote
Old 01-02-2005, 01:32 AM   #2
thx247
thx247 is an unknown quantity at this point
Its the hatch, and I don't know where. I remove the carpet and pull the drain plug under the spare tire.
thx247 is offline   Reply With Quote
Old 01-02-2005, 01:44 AM   #3
idlafie
idlafie's Avatar
Check the rubber seals around your taillights, along with the seal on your rear hatch. Those are usually the main spots where water gets into your vehicle. If you have a rear spoiler, it's possible the water could be leaking thru the bolt holes where the spoiler bolts down to the hatch.
Anyhow, hope this helps...
ID
Old 01-02-2005, 01:53 AM   #4
s13irdie2
s13irdie2 is on a distinguished road
mine leaks too!! but i dont kno where it leaks from so i just dont put anything in the hatch anymore
1990 s13
IslandMotorsports, Inc.
s13irdie2 is offline   Reply With Quote
Old 01-02-2005, 10:23 AM   #5
SimpleSexy180
Mine used to leak until i fixed it. If you look at your weather strip follow it all the way down to the taillights and on top youll probably see a gap between the plastic and frame. The water leaks behind the lights into the spare tire compartment. I used window sealer stuff to seal those areas so the water will just flow right over where the gaps used to be .
SimpleSexy180 is offline   Reply With Quote
Old 01-02-2005, 10:57 PM   #6
Inland180
Inland180's Avatar
Inland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant future
Send a message via AIM to Inland180
do you have a oem hatch wing? if you do then it might be getting in throught the holes where the wing is attached to the hatch.
PTE6262 Full-Race Twin Scroll FTW!
Feedback LINK
Inland180 is offline   Reply With Quote
Old 01-03-2005, 12:57 AM   #7
AllenRPS13
AllenRPS13's Avatar
yes, i have the OEM spoiler on my s13, i also think that the water go into the trunk by the holes... but what can i do to stop it? anyone know? or it's not fixable? just like u guys have the OEM spoiler?
~小アレンのリベリオン~
