Old 03-18-2002, 04:24 PM   #1
DSC
New Title
DSC is an unknown quantity at this point
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cry.gif" border="0" valign="absmiddle" alt=''> My car feels fine but it makes a "clunk clunk clunk clunk" sound when i'm first starting off, when I'm driving slow or when I come to a stop. I have absolutely NO CLUE what to look at <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/nervous.gif" border="0" valign="absmiddle" alt=':nervous:'> Sway bars are still attached properly, tire pressure is good, shocks feel fine and I don't see any leaking...I dono what else to look at. I didn't notice it untill I lost traction (had just started to rain...still driving like it was dry). The light turned green and I was trying to take off fast cauz my lane ended ahead and I just sat there spinning my wheels for about 2 seconds when I got traction and speed off. I don't see how that could have hurt anything but its the last thing I can remember doing before I started hearing this clunk sound. Anybody have a clue what it could be? <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/eh.gif" border="0" valign="absmiddle" alt=':eh:'>
DSC is offline   Reply With Quote
Old 03-18-2002, 05:08 PM   #2
geeaj
geeaj is an unknown quantity at this point
drive shaft mounts...tranny mounts..motor mounts are all likely causes. Most likely drive shaft or tranny mount.
Beware the fury of a silent man, be more cautious of his silent farts....
geeaj is offline   Reply With Quote
Old 03-18-2002, 05:09 PM   #3
DrDubbleB
DrDubbleB is an unknown quantity at this point
Can you tell the direction it's coming from? Is it coming from the front or back of the car? If it's coming from the front, when it clunks, can you feel anything? Is it a loud clunk, or not? Does it sound like metal on metal? Do you still lose traction easily? Could be a bunch of things, more information is needed.
DrDubbleB is offline   Reply With Quote
Old 03-18-2002, 05:13 PM   #4
geeaj
If the clunking comes from the front, either during acceleration or deacceleration, then it could be the motor mounts. If its a "woppp..woppp" type noise, could be wheel bearings too. But usually not a clunking.
It if comes from the rear, during accel or decel, or during downshift, it could be the driveshaft mount, tranny mount, or maybe even your rear end.
Old 03-18-2002, 06:37 PM   #5
DSC
New Title
Umm I dono what the hell it was. &nbsp;I just took it for a spin so I could more accurately describe the sound it was makeing and it wasn't makeing it. &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/eh.gif" border="0" valign="absmiddle" alt=':eh:'>
It will most likely rain again in a day or two so I'll let you all know if it comes back. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Old 03-18-2002, 08:35 PM   #6
junia
junia is an unknown quantity at this point
Send a message via Yahoo to junia
My friend had that happen in his FD and it was his diff. &nbsp;We just changed it out with another one from a junkyard and that fixed the problem.
1990 Nissan 240sx hatchback, 1991 Nissan Silvia K's PS13, 1978 Toyota Corolla KE-30
junia is offline   Reply With Quote
Old 03-18-2002, 10:33 PM   #7
Guest
Posts: n/a
if u have hubcaps, maybe it's your hubcaps.
Old 03-18-2002, 10:46 PM   #8
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
it could be the rubber protector on the strut? i have no idea what it's called, strut boot? &nbsp;sometimes it breaks and... i don't know why it makes that noise, but i had it on my tercel, and i decided to glue the rubber back, and it was fine... till one day... SMACK, totaled...
240meowth is offline   Reply With Quote
Old 03-19-2002, 12:01 AM   #9
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
was it wheel hop dsc? if so check your subframe bushings with a prybar see how much play there is.
also see if your tensio rods are good and tight. i had left mine loose so i heard a clunk everytimes i applied the brakes. other than that also check your exhaust see if the cat bracket and all the hangers are good could be your exhaust hitting your trans your undercarraige or diff.
i would check that first a nice hanger would be the easiest (ghettoest) fix <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 03-19-2002, 07:25 AM   #10
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (camppain @ Mar. 19 2002,01:01)</td></tr><tr><td id="QUOTE">was it wheel hop dsc? if so check your subframe bushings with a prybar see how much play there is.</td></tr></table><span id='postcolor'>
Got Clunk!
This one appears at all times, in low gears, whenever you drop off the throttle and the car dips forward. &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sneaky.gif" border="0" valign="absmiddle" alt='issed:'>
And it's a PITA to fix!
(I'm hoping these are not your symptoms)
HippoSleek is offline   Reply With Quote
Old 03-19-2002, 09:47 AM   #11
camppain
camppain's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (HippoSleek @ Mar. 19 2002,8:25)</td></tr><tr><td id="QUOTE"><!--QuoteBegin--camppain+Mar. 19 2002,01<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (camppain @ Mar. 19 2002,01<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>1)</td></tr><tr><td id="QUOTE">was it wheel hop dsc? if so check your subframe bushings with a prybar see how much play there is.</td></tr></table><span id='postcolor'>
Got Clunk!
This one appears at all times, in low gears, whenever you drop off the throttle and the car dips forward. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sneaky.gif" border="0" valign="absmiddle" alt='issed:'>
(I'm hoping these are not your symptoms)</td></tr></table><span id='postcolor'>
you can say that again 6 hours labor at my dealer torch and anything to get theem out <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'>
but i just got the whiteline subframe bushings i didnt feel like torching stuff out blah blah blha etc etc tehy work great i must say no more wheel hop
Old 03-19-2002, 12:15 PM   #12
HippoSleek
HippoSleek's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (camppain @ Mar. 19 2002,10:47)</td></tr><tr><td id="QUOTE">but i just got the whiteline subframe bushings i didnt feel like torching stuff out blah blah blha etc etc tehy work great i must say no more wheel hop</td></tr></table><span id='postcolor'>
The "Drift Pineapples"?
I was seriously thinking about getting those. &nbsp;How much are they/where did you get them? -Don? &nbsp;How much work was it to get them on (I've heard third hand they are cut and just slip on)? &nbsp;Did you have to jack the subframe up and just slip them in or was it a bit more complex?
Oh - and in the above description, you left out the fact that the damn bushings themselves are outrageously expensive (Nismo's are about $200, IIRC).
