Old 01-23-2005, 08:31 AM   #1
DaN_S13
DaN_S13 is an unknown quantity at this point
CA Help!! car won't run
I'm having some engine troubles and have no clue whats causing it. I have a 91 Silvia s13, ca18det. i dropped in an engine not too long ago and it hasn't been running since. It will start up and idle really rough like its on 3 cylinders for about a min then dies. Any time i try to give it gas it dies out, unless i hold the throttle open and start it up then it will rev up to about 2000rpm and sputter and backfire. there is also gas dripping out of the exhaust and when i pull the sparkplugs out 1,2,and 4 are soaked in gas while 3 looks good.I've got new spark plugs in it and the coil packs seem to be fine. i've tried swapping them out with extras that i have and still no difference. I checked the timing on it and that was fine and i did a compression test and came up with: 161,161,158,179psi . is this alright?? Any ideas as to what might be wrong?? Also that engine that i pulle d out of it was still running fine so i dont think its anything to do with the electronics. Any help would be greatly appreciated. thanks
-Dan
DaN_S13 is offline   Reply With Quote
Old 01-28-2005, 01:40 AM   #2
stealthj
stealthj is making a name for him/her selfstealthj is making a name for him/her self
Send a message via AIM to stealthj
i have EXACTLY the same problem, anyone have any clues or ideas as to what might be going on?
-Kevin
Z31T s13 hicas
stealthj is offline   Reply With Quote
