Old 04-04-2005, 08:21 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
altima elec fan install on s14
i see there isnt anything on this websites installs about this, anyone know of a link that would show a step by step on how to do this?
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 04-05-2005, 08:03 AM   #2
orion::S14
orion::S14's Avatar
Easy...I just did it last weekend.
1) You have to trim 3/4" off either side of the bottom (from the very bottom to about 5" up)
2) You have to notch the pass side where it will hit the battery tray
3) Wiring - Stock S14 plug should work for one fan (or you can swap the S14 e-fan/motor into the pass side of the Altima fan bracket, so it's plug and play FOR SURE)...the other needs to be hard wired USING A RELAY. I used 2 other OEM relays in the stock fusebox.
Keep i mind..there are 4 wires b/c EACH fan has a high and low speed. Power and ground to either pair of wires is low speed...power and ground to both pairs is high speed. And one 30amp relay may not be able to do the job...I've seen dual 10" FAL fans melt Bosch relays, so I wouldn't chance it.
4) Only one of the little "pins" on the bottom will slide into the factory S14 bosses...and the top mounts will be close, but will need to br redrilled to fit exactly.
Hope that helps - Brian
www.KA24DEvelopment.com
