from Canada, eh!
![]() Join Date: Sep 2001
Well I'll be damned..
I just test fitted my 245/45R16 on my 16x7+32 Advan wheel... on the front of my S13 with D2 Coilovers... And you know what? No spacers are required... I just got some H&R 15mm spacers just in case and I won't need them... It doesn't even touch the inner fender. I am really surprised..
-> HaLo Race Car: '98 E36 BMW M3 Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
![]() Join Date: Sep 2002
really? wow... how much camber are you running? i have some 16x7.5 with 205/55 and they won't fit with my coilovers (not d2). i got some 5mm spacers and they barely clear. oh, the offset is +40
#4 | |
my 245/45 clears in the front with my d2s with a 16x7.5 with a 22 offset. Whattaya know, d2's are good at somethin eh? haha
#6 | |
#7 | |
![]() Join Date: Apr 2003
Jason '95 240sx SE |
from Canada, eh!
I will hold on the spacers just to widen the front track to reduce understeer.
#9 | |
#10 | |
Why do autocrossers tend to put such huge tires on wheels? A 245 seems more at home on an 8-9" wheel than on a 7". For example, I would think that for a 7 F 8R combo, 225 and 245 would be good healthy tire sizes. Yet I routinely see people go even wider than this. Is there a benefit to cramming so much tire on seeing as grip is mostly a function of compound?
#13 | |
I am with turtl, I'm also curious why people run such big sizes, is there a benefit that we're not seeing here? |
#14 | |
from Canada, eh!
225/245 combo doesn't. I guess you can't apply some road racing/lapping rules on auto-x.
#15 |
![]() Join Date: Dec 2002
Clearance also depends on the specific tire you're running. My ES100's don't have the same shape compared to my Avon's
Well the results from autox in my region tend to give better results to the guys with the wider tire. There are so many variables in there though as you all know. You can go too big; too much rotational inertia, affects to your suspension, and not being able to get them to optimal tire temperatures... Tires are very hard to analyze so it is difficult to determine the best width. The best way is to test. I'm running 225's, will go to 245 next season to know how they differ for my setup. |
#16 | |
#17 | |
#18 | |
#19 | |
the tires he's running probably are R compounds which have very little flex...
![]() HighTach Motorsports |
#20 |
^^this is true, on a street tire, sure, there would be too much shoulder flex, but on ao32's, doubt it
#21 | |
#22 |
from Canada, eh!
Thanks a lot guys for explaining what I could not.
![]() I am running A032R, which are Race tires. I also ordered some Hoosiers and will see what I can do with those. ![]()
#23 | |
(and ghambino, what you said is still wrong, more patch DOES not mean more grip, think an R compound tire w/ a smaller contact patch vs. Wal mart tire w/ bigger contact patch. AND wider tires DO NOT always mean more total patch area, maybe more "horizontal" patch that helps w/ lateral stability.) I'm not arguing against you autocrossers that run this set up, obviously there's alot more to it then simple physics, I am just simply wondering why. |
#24 | |
I work on some club racer's cars on weekends from GT3 to FF1600's. They are limited on wheel width, but they cram as much tires on there as possible. These tires are specially made to be so very wide on a skinny 7" rim. Sidewalls are so stiff that if you get a flat, it is hardly noticable statically. I heard Hoosier's should blow A032R away easily, tell me if it really does. |
#25 | |
I am comparing apples to apples, just merely informing ghambino that not only did he NOT answer the question at hand, he missed 2 critical truths of the laws of physics...
with that said, I am not arguing that bigger tires won't give you better times, you guys are the experts here, I am merely asking why they do, even though doing so seemingly goes against physics... so far 3 people have reaffirmed the fact that most people run as much tire as possbile, but no one has replied why. Quote:
#26 | |
so far your post has given the most info on the question, there's probably many variables that come in play, and I do see autocrossers running wider tires alot, just trying to understand the physics behind it.
#28 | |
Now we all know that's only part of the game, as obviously wider tires DO do better, and so far I've only found 2 possible explanations: 1. the wider tire offers more horizontal/lateral patch 2. better heat dissipation I'm merely looking for some more explanations, it'd be nice if I could know why doing something helps. |
#29 | |
![]() Join Date: Feb 2003
Let me see if the intranets has anything useful... BINGO!: http://hyperphysics.phy-astr.gsu.edu...rict3.html#are Then click the "coefficient of friction" in the last paragraph. So there you go, those tricky physicists are making assumptions that aren't quite valid for autoracing.... or you can just tell all your friends that your car defies physics. ![]() -Matt
![]() '89 Nissan 240SX fastback: #23 DSP/RallyMod2/Track Slut '95 BMW 540i 6 speed: Ultimate Commuting Machine PFM Racing www.solo2.org www.midwest240sx.com |
#30 |
I did some research and came up with this:
http://forums.bimmerforums.com/forum...d.php?t=328261 Quick summary: "For anyone who liked the "wider tires aren't any faster" debate... I would suggest running out to Barnes and Noble and picking up the March issue of Racecar engineering. The very last article in the mag (last 2 pages actually) deals with this exact topic. The author admits that everyone 'knows' that wider tires are faster, but also that, scientifically speaking, they really shouldn't be. That is a huge and horrible oversimplification, but in case anyone was looking for a definitive answer I want them to know this isn't it. What is in this article is a couple of theorys as to why wider tires appear to be faster and also a quick explanation of why they shouldn't be. There is also supposed to be a second article in the series in the next issue so keep an eye out for that as well. I'm not trying to start the whole debate again, but the article was a good summary of the whole tire paradox and at least one of the why-wider-is-better theorys was something I'd never heard mentioned before. Anyway, just go read it, it's quick and interesting." And, this from a guy who read the article and summed it up: "Here's a brief synopsis though. (of my posts, or the article...? hard to tell... ) - Columb's law for friction - Tires contact patch area does not vary with its width. - Tire width, construction, and inflation pressure change the contact patch shape, not size. - If we take a narrow tire and make it wider, the contact patch stays the same size, but gets wider and shorter. - A wider tire has a greater surface area in contact with air to surface area in contact with the ground ratio. - Wider footprints (contact patch shape) have smaller region of acceptable slip angles that are within the grip zone of the tire." Basically I think this is very interesting, as it seems zilvia.net isn't the only forum having trouble to explain WHY wider tires are faster, hope this helps. |
