Old 04-13-2005, 07:14 PM   #1
struka
struka is on a distinguished road
Send a message via AIM to struka
Air bags
Ok i did some research about this one. But not a lot of people just turn off their air bags. I have a 95 with airbags. I just want to turn them off when ever so they dont deploy on me cuas i will have a bucket seat and a roll bar. SO i dont need airbags.
What i was gonna do is undo the battery and wait for 30 min or so and unplug the sensor that is under the back seat...but someone also suggested to take out the relay for the airbag. Should i take out the relay than unplug the sensor? I know my light will be on but thats ok.
Team Rowdy
struka is offline   Reply With Quote
Old 04-13-2005, 08:44 PM   #2
projectRDM
projectRDM's Avatar
There is no relay. Unplug the module or either bag itself.
FORMERLY R240NA
Old 04-13-2005, 09:42 PM   #3
dizoita
dizoita is an unknown quantity at this point
^^^^What he said or CUT IT
dizoita is offline   Reply With Quote
Old 04-14-2005, 12:24 AM   #4
Kouki
Kouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud of
You do not have to unplug the battery. When you pull the plug from the module that takes away any chance that the air bags will deploy. There will be absolutely NO current that could go to the airbags even if the battery is hooked up. If you cut the wires with the battery hooked up that is a different story, cuz when the metal cutters passes through all the wires at the same time, the current will flow. If you just unplug the wires you will be safe.
Kouki is offline   Reply With Quote
Old 04-14-2005, 09:36 AM   #5
struka
ok, i will just unplug it and not cut. cutting it will be kinda pointless just in case i want to plug them back in. and if i want to plug it back in...i just plug the module in and rest the air bag to work?
Team Rowdy
Old 04-14-2005, 10:18 AM   #6
importnut
importnut's Avatar
importnut is an unknown quantity at this point
Unplugging it will not keep it from working down the road. It's much smarter to unplug than to cut. If you want to activate them down the road, just plug it back in. No problem.
-Alex S.
"What about the twinkie?"
importnut is offline   Reply With Quote
Old 04-14-2005, 04:05 PM   #7
projectRDM
projectRDM's Avatar
Correct. Reset before use.
FORMERLY R240NA
Old 04-14-2005, 04:49 PM   #8
my240iguanas
my240iguanas is an unknown quantity at this point
Send a message via AIM to my240iguanas
sell the module on ebay after you take it out
my240iguanas is offline   Reply With Quote
Old 04-14-2005, 09:35 PM   #9
struka
i dont want to do that. because i will plug it back in later (so i think)
y do u need one?
Team Rowdy
Old 04-14-2005, 11:24 PM   #10
Kouki
That little box, aka module, is the brain, that is what tells the airbags when to blow.
Old 04-15-2005, 12:05 PM   #11
struka
yea, and u have to get a new one if ur air bags blow out (which i had to cause my car is salvaged and i had to rebuild it) kinda sucks that i had to buy it to pass the inspection and now i want to unplug it.
Team Rowdy
