from Canada, eh!
![]() Join Date: Sep 2001
Weird issue with my SR.... Lots of questions!
Hey guys,
Got a question for you. 2 days ago, my dipstick shot out and poured some oil in the engine bay on my S13 SR. It did that on a 1-2-3 up to 120km/h on 7psi and the stock T25. I tested the compression: 150 psi on all 4 cylinders. I checked the PCV valve, it seems to work properly. There is no oil in the blow-off valve or intercooler piping. When the blow-by occured, all gauges were reading nominal, except oil pressure that might be a tad too high. I recently intalled a catch can in between the Valve cover T and the intake. The hoses are a little smaller than the oem ones. Could that be it? Another thing I notice: Inside the black hose between the black box and the Valve cover T, there is a small brass "restrictor" that reduces the diameter of the opening to maybe a 3mm diameter circle: IS that supposed to be there? I also notice I might have put too much oil on the last oil change. I put maybe around 4.5L, which would be 0.8L too much. Would that cause the dipstick to fly out? Can I assume that my turbo seals are ok, since there is no oil in the BOV and it doesn't smoke? Can I assume my rings are ok because my compression yields very good results? I am thinking I might have had too much oil and it might've been the cause... What is your verdict?
-> HaLo Race Car: '98 E36 BMW M3 Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
