Old 05-20-2005, 01:38 PM   #1
thejester03
thejester03 is an unknown quantity at this point
Send a message via AIM to thejester03
Blue Smoke.
Ok, i know there was another post about this not long ago, but that had to deal with turbo. I was in a drive through yesterday, w AC running and realized i was smoking out the tail pipe, blueish grey smoke. Well, when i took off, it smoked for like 1/2 a block, and quit. then later that day it did the same thing at a stop light, but only seems to do it when the AC is running. What is wrong? Oh yea, stock S13 Coupe.
thejester03 is offline   Reply With Quote
Old 05-20-2005, 01:46 PM   #2
Var
Var's Avatar
Send a message via AIM to Var
damn i thought Kumho put out another tire
Hi
Old 05-20-2005, 01:52 PM   #3
thejester03
Huh?????????
Old 05-20-2005, 03:14 PM   #4
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
I got the joke =)
But check inside of your inter cooler piping for any oil, that would be the first place to start. Then from there its time for compression, and leakdown tests. You are burning oil son
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 05-20-2005, 05:26 PM   #5
thejester03
I dont have a turbo, so that could be hard.
Old 05-20-2005, 06:58 PM   #6
wootwoot
For some reason I always assume that. Just go straight to the other two I listed; pull some plugs and look for oil
Old 05-20-2005, 07:12 PM   #7
thejester03
Thanks, Any more input is greatly appreciated.
Old 05-20-2005, 11:16 PM   #8
Prep Guy
Prep Guy is an unknown quantity at this point
just do a compression test and see if your rings are bad.
Prep Guy is offline   Reply With Quote
