is this the ecu? safc install ? URGENT!
new to electronics, and i am working on installing this safc. i believe the ecu is the white box going vertical with the 10mm bolt in it. so i am assuming i just remove the 10mm bolt and the top of the white plastic casing and splice the correct wires. let me know if im wrong or right please. this is on s14 by the way, with ka
![]() ![]() thanks and sorry for such a newbie question...
WTB-NARDI wheel & NRG 2.8 QR |
![]() Join Date: Mar 2003
![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Hey i helped you pull the dash off that bitch. Good luck with the install Devo!
92 Hatch, KA-T, T28, 12 PSI, FMIC, 3" TBE, EFI ECU, 440cc Inj, And more... |
![]() Join Date: Dec 2004
installing the SAFC and or setting the initial settings incorrectly can seriously F UCK your motor up...make sure you read the directions in both books and flip back and forth a few times to make sure you know what your doing...choose the wrong pin and you could jack it up as well...and make sure you solder the wires and do it right the first time..not black tape....asking where the ECU is on the car while installing the SAFC sounds like you may want to ask for some help first
good luck
ZEROYON WEBSITE IS HOMO NEW SITE: blacklinux.com/innersanctum/index.php |
other than making sure the wires are right (obviously) do i need to take any special precautions when working with the ecu?
i am gonna agree...i don't recomend doing that job unless you are confident with your electrical skills. Your gonna have nothing but problems unless you do it perfect. But if you insist on doing it your self, good luck. Pick up a soldering iron, solder with flux, and some heatshrink to shrink over the individual connections.
![]() Join Date: Feb 2004
for real man, if you need some help with this me, robbie, matt, john etc of MA240sx, should be able to help you. personally I'll install it for $30 which is pretty damn cheap...
To quote the great Ron White: if life gives you lemons, make lemonade. and try to find somebody who's life gave them vodka, and have a party |
yah dont do it yourself, because splicing wires is sooooo hard, and reading instructions is even harder. *sarcasm*
or take nismos offer, but make sure he explains it to you also. Remember that saying, Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime. |
#14 |
splicing wires and such isn't nescessarily hard, but shorting out a wire because of one little mis-movement and consequently shorting out an entire ecu can be expensive...
#15 | |
Just like I said, ask for some help then next time he will be able to help someone else...I have installed 3, the first one was on my Sentra and I had help, now on my 180 it tiik like 10 mins... get some help with it... late Daryl
#16 |
listen to everyone mang....don't do it yourself if you don't know what your getting yourself into..especially if you can't even tell if that's your ecu or not....i'm not trying to be an asshole or anything too. seriously i'm not, check my post about how i fucked up my install...i did mines a couple of days ago and i finally got it to work like 15 mins ago. so if your unsure don't like others have said it can seriously fuck your motor up bad!! but incase you need the pinout guide i posted it in my thread!!!
#18 | |
![]() Join Date: May 2005
#19 | |
AFC #1
![]() Join Date: Oct 2003
#20 |
^agreed, I live maybe an hour from the guy, if that, which is why I offered to help...
#21 |
First disconnect the battery
get a diagram, study it, read all the instructions on the manual and all SAFC installation threads for S14 all over the net. Get a FSM, you will thank me later Identify the wires, all of them, before doing anything, double check with both Apexi and FSM diagrams. Be sure to look at the diagrams correctly. Like other said, you can short your ECU at least. Get some splices, connectors and electrical tape. Befoer cutting anything.. leave some wire as slack, just in case you need to reconnect it. Be sure NOT to leave any exposed wire, reconnect the ECU (if you removed to connect the SAFC), double check, triple check and connect the battery. Before starting the car, be sure to reset the SAFC, even it is brand new, check SAFC manual for this. Then set up the safc for the correct setting for your car, do the sensor check on the safc and then start your car. Verify idle speed. All corrections on the safc must be 0 if you have stock injectors. If you have changed to bigger injectors adjust them accordingly in the correction map before starting the car. Good luck!! |
