![]() Join Date: May 2005
![]() i already tried searching and couldnt find anything. my friend and i were bored so we rented a compression guage from auto zone and got these readings. i remember reading somewhere about good #'s and bad ones, but i cant find them...
My ka24de 1=175 2=180 3=175 4=180 My friends ka24e (i might be off give or take 1 psi, im posting his by memory) 1=160 2=165 3=161 4=167 ![]() |
![]() Join Date: Sep 2002
Yours is good and your friends isn't too bad either.
My 240 vBgarage |
![]() Join Date: May 2004
off of the 240sx.org faq (http://www.240sx.org/faq/articles/compression_test.htm)
"Compression Pressure kPa (kg/cm2, psi) / RPM Standard = 1,236 (12.6, 179) / 300 Minimum = 1,040 (10.6, 151) / 300 Difference limit between cylinders = 98 (1.0, 14) / 300" |
And those numbers are with WOT@300RPM, don't forget that...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
how do you do it at 3000rpm? the throttle was wide open, we did it the way we knew how to, cut fuel, remove all spark plugs, and crank the engine with the guage in each sparkplug hole
![]() Join Date: Jan 2003
the specs are specified @ 300 rpm (not 3k), which is the speed your engine *should* crank at with the starter when the motor is warmed up. variation in that speed will cause variation in your numbers.
