LSD install
Im putting a tomei 2-way into a 1990 open differential. So far i've pulled the pumpkin out and takenn off the cover. I was wondering if any of you guys had a picture of diagram of how the LSD goes in?... I dont want to mess anything up. Also what are the shims?
![]() Join Date: Jul 2004
Remove all the bolts. Pop out the output shafts with a pry par(pops right out). Install is the exact opposite. It's going to be difficult to install the shims(use same shims). So make sure you get your bearings pressed in nice, tight and even. Good luck.
#3 | |
Shims are spacers(huge washer) to keep the diff aligned with the pinon gear.
http://www.zilvia.net/f/showthread.p...ighlight=tomei |
#5 | |
Ok I got another problem. I cant seem to get the diff out of the pumpkin. I already took the 4 17mm bolts that where holding down the bearings and ive tried pulling the diff out and it wont budge.. any ideas?
