Old 07-31-2005, 04:46 PM   #1
Silvia1EightySX
Silvia1EightySX is an unknown quantity at this point
power antenna
im not to sure about whats wrong with it. the antenna doesnt raise itself up nor does it lower itself. when the car is turned on or off, it just makes this noise. i can pull the whole thing out however. but its bent now cuz someone decided it was funny to bend my antenna or somethin? but before that i had a little reception, now its gone. to remove it, i would have to get pliers or somethin and get it out of the rubber from the driver side panel, right? i've never done this before. i was told in order to remove it, i would have to do it from inside the trunk but theres that metal piece blockin it. is there any replacement for havin a power antenna? so i wouldnt need a antenna for it? i wouldnt want another bent antenna, if i'd have to replace it.
Silvia1EightySX is offline   Reply With Quote
Old 07-31-2005, 05:27 PM   #2
Rusted_PS13
Rusted_PS13 is making a name for him/her selfRusted_PS13 is making a name for him/her self
Im not sure how to remove the whole system, but to just remove the tip, all you have to do is get a flathead and a hammer, and where the grooves are on the black thing i think it has two. Take the flathead and stick it in there then tap it with the hammer. My antenae is broken, but for some reason im still catching reception...im thinking about putting a "S2000" style antenae on there so water wont get in.
Rusted_PS13 is offline   Reply With Quote
Old 07-31-2005, 08:59 PM   #3
Silvia1EightySX
k, thats what i thought i might of had to do, in order for me to replace it. cuz the person that told me didnt know about that metal piece blockin it. he has a coupe model that doesnt have power antenna. there's no way for me to get rid of the power antenna and still have reception is there?
Old 08-01-2005, 06:44 AM   #4
jmauld
jmauld is making a name for him/her selfjmauld is making a name for him/her self
Send a message via AIM to jmauld
It's fairly easy to replace the antenna with a non-power one. I could not find an aftermarket antenna with the plug that mine had in it, so I found one from a car being parted out.
I believe there are only two bolts holding the motor of the antenna in. Just unscrew the top of the antenna, remove those bolts and it slides out.
Jason
'95 240sx SE
jmauld is offline   Reply With Quote
