Old 01-19-2005, 04:57 PM   #1
rps13_fastback
rps13_fastback's Avatar
rps13_fastback can only hope to improve
Send a message via AIM to rps13_fastback
Battery relocation wiring Q
Hi guys, I relocated my battery to the trunk a few weeks ago.. was in a rush because I was putting in my FMIC.. anyhow, I did it the super ghetto way, just put a ring terminal on some Home Depot super stiff 2 gauge wire, and hooked it up to the thing that goes on the positive on the battery. Grounded the battery to the trunk floor.
I did some searching and some people put the positive lead on the starter.. is this correct? What about all the other stuff like the black and green plug (that plugs into the big red plug) that touches the positive? Please bear with me as I have very little wiring knowledge. Thanks
rps13_fastback is offline   Reply With Quote
Old 01-19-2005, 07:58 PM   #2
projectRDM
projectRDM's Avatar
Bolt the lead from the battery to the starter.
Then either insulate the battery terminal and tuck it away, or tie it all together somehow at the terminal.
FORMERLY R240NA
Old 01-19-2005, 09:03 PM   #3
TheTimanator
TheTimanator's Avatar
I haven't finished mine yet. I've the battery box mounted for 6 months empty...ha!
Anyway, I'm planning on using one these things. Hopefully it will make it easier to clean things up
http://img.photobucket.com/albums/v3...r/000_0204.jpg
Old 01-19-2005, 09:29 PM   #4
RSP13-Sideways
RSP13-Sideways's Avatar
RSP13-Sideways is making a name for him/her selfRSP13-Sideways is making a name for him/her selfRSP13-Sideways is making a name for him/her self
Send a message via AIM to RSP13-Sideways
What's crazy is you didn't take out your battery box, you just cut right the sucker.
I removed my battery box and it was a biatch...
- Jay
WTB: Nothing at the moment. LEWL
WTS: Everything sold, thanks folks!
RSP13-Sideways is offline   Reply With Quote
Old 01-19-2005, 09:36 PM   #5
ruthlesstyper
ruthlesstyper is an unknown quantity at this point
Most people just cut through it buddy..
ruthlesstyper is offline   Reply With Quote
Old 01-19-2005, 09:42 PM   #6
RSP13-Sideways
Most people are lazy.....
- Jay
Old 01-19-2005, 09:56 PM   #7
rps13_fastback
So the battery terminal and that red connector doesn't need to be hooked up to the positive on the battery?
Old 01-19-2005, 09:57 PM   #8
rps13_fastback
You mean the battery tray? I wanted to but didn't know how to take out the spot welds.. also looked like a big PITA. How did you do it?
Old 01-20-2005, 09:10 AM   #9
RSP13-Sideways
The spot welds are the hardest thing. Just drill them out because you're going to have to cut a hole there anyway. I made my hole a lot larger though, so when I upgrade my intercooler I have room to play with.
- Jay
Old 01-20-2005, 09:20 AM   #10
projectRDM
projectRDM's Avatar
Think about it for a sec.
Battery power flows to the starter terminal.
The positive terminal lead to the starter is still there as well.
Power flows through the terminals on the starter up to the battery terminal.
Power flows through the terminal to the fusebox.
FORMERLY R240NA
Old 03-25-2005, 11:55 AM   #11
s14srpilot
s14srpilot's Avatar
s14srpilot is an unknown quantity at this point
Send a message via AIM to s14srpilot
I know this is an old thread. I searched and looked at a bunch of other threads but didn't find an answer to my question. I'm just wondering about the gases that batteries emit. If I buy an optima and relocate it to the trunk without a battery box should I worry about this? My car is a daily driver. Thanks!
s14srpilot is offline   Reply With Quote
Old 03-25-2005, 12:10 PM   #12
the head
the head's Avatar
with an optima you should not have a problem and as long is the car is not a hatch and has a back seat you dont need an externally vented battery box
always use a battery box shit the marine ones are under 20 at any auto parts store if you are being totally cheap use that
Old 03-25-2005, 03:36 PM   #13
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
hatch or not, any trunk mounted battery that is not a 'dry/gel' cell needs to be vented. Your trunk is hardly air tight even in a coupe.
Regardless if you know people without problems, it's not safe.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 03-25-2005, 03:55 PM   #14
the head
the head's Avatar
safe or not I am just saying that for teh drag strip if it is in hte trunk and you have a rear seat in a coupe it is legal
Old 03-26-2005, 11:55 AM   #15
s14srpilot
s14srpilot's Avatar
So to restate the answer to be sure I understand: If I get an Optima yellow top=Dry/gel cell then I don't need a battery box, hatch or not, with a back seat, correct?
Old 03-26-2005, 12:18 PM   #16
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
It probably depends on how strict they are at the track you go to, but it seems to me that you wouldn't pass tech inspection if they saw your trunk mounted battery w/o a box, because at that point it's a liability issue for the track management if anything goes wrong on your run.
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 03-26-2005, 01:19 PM   #17
projectRDM
projectRDM's Avatar
Optimas are gel cells, they don't need to vent and you can mount them upside down if you want.
Standard sealed type batteries require venting, even if it's in the trunk.
FORMERLY R240NA
Old 03-27-2005, 12:25 AM   #18
dekand
dekand is an unknown quantity at this point
Send a message via AIM to dekand
easiest way to bolt the + lead to the harness is with a bolt/nut and washer. you put a washer on each side of the existing harness terminal, then send a bolt through the new + terminal and a bolt on the other side and tighten it all up, walla... done. id get a pic but im tired and lazy...
No Signatures over 400x200!!
dekand is offline   Reply With Quote
Old 03-27-2005, 01:11 PM   #19
Rusker
Rusker's Avatar
Rusker is on a distinguished road
word......
1990 S13/SR20
Rusker is offline   Reply With Quote
Old 03-27-2005, 11:06 PM   #20
180SXtc
180SXtc is an unknown quantity at this point
Send a message via AIM to 180SXtc
Just out of curiousity where did you ground your battery in the trunk?
91' hatch
RedHead SR20DET
Apex-i N1 Cat Back
HKS Downpipe
Blitz LM FMIC
Sr20detperf Hot Pipe
HKS SSQ
Apex-i Intake
Rays 77w 17x8
Eibach sportline
Tokico Illumina
180SXtc is offline   Reply With Quote
Old 03-28-2005, 08:19 AM   #21
the head
the head's Avatar
no man I just said you dont need an externally vented box you still need a box of some sort
Old 03-28-2005, 08:22 AM   #22
the head
the head's Avatar
they dont need a VENTED BOX you still need a BOX of some type to pass tech get a plastic marine box and call it good like I said they are about 20 or 25 dollars
the reasoning behind this is it protects the terminals from grounding to the chassis in an accident if the batt breaks loose from its mountings electrical fires are bad and this helps to prevent them
Old 07-30-2005, 06:30 PM   #23
cinci_s14
cinci_s14 is an unknown quantity at this point
Is there an advantage to bolting the lead from the battery to the starter, rather than bolting it to the oem lead that was originally attached to the battery? I'm in the middle of my battery relocation and am a little confused about this recommendation...
cinci_s14 is offline   Reply With Quote
Old 07-30-2005, 08:25 PM   #24
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
my pos. lead is rigged to the original lead for now. i'm going to either run it to the starter or pick up a distribution block. i'm not leaving it where it is now, it just doesn't look very clean
sncs14 is offline   Reply With Quote
Old 07-31-2005, 02:04 AM   #25
junkilo
junkilo's Avatar
junkilo is an unknown quantity at this point
under the trunk mat sand it down till its bare metal and lag bolt the lead on there good n tight.
cutting out the oem battery tray is a pain. I took to it with a crowbar, sawzall and hammer. a drill is a good idea to break apart the annoying parts.
junkilo is offline   Reply With Quote
Old 07-31-2005, 10:24 AM   #26
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
one of the teachers in the automotive program at my school, the teacher for electrical systems, told me that gel cells do indeed create the same gases as normal batteries, so a vented box is still a good idea.
and just to have correct terminology, power doesn't flow, current flows through wiring diagrams.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 08-01-2005, 08:08 AM   #27
the head
the head's Avatar
My system is wired to the original leads using a 150 amp marine circut breaker it works great and gives me aa handy place to power down the car when i put it in storage.
Old 08-01-2005, 11:01 AM   #28
junkilo
junkilo's Avatar
yea regular circuit breakers work for dc and ac in terms of a mock kill switch.
Old 08-01-2005, 12:52 PM   #29
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Damn, right thru it.
I hate electrical, so i'll give you props on one of the cleanest battery trays ever!
And I'll read to learn more.
SochBAT is offline   Reply With Quote
