Old 09-20-2005, 12:32 PM   #1
steve shadows
steve shadows's Avatar
High Hp Na Ka-24e
any Info would be great.
Looking for 180WHP.
Like Me on FaceBook !
Old 09-20-2005, 12:51 PM   #2
NemeGuero
No more nissan.
NemeGuero's Avatar
easily done.. there are a bunch of other threads about it..
http://www.zilvia.net/f/showthread.p...hlight=200rwhp for example...
also ITBs are an option
basically you need to get the KA to breathe a little better.. high flow head, cams, etc..
Old 09-20-2005, 12:53 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
and lighten up the drivetrain too... (flywheel and possibly 1piece aluminum driveshaft) will greatly reduce the rotational mass and provide you better response
Old 09-20-2005, 01:10 PM   #4
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Google up SCCA KA24E. They've been making use of the SOHC.
SochBAT is offline   Reply With Quote
Old 09-20-2005, 01:13 PM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
ah crap, didn't see that it was 24E.. well same info still applies
Old 09-20-2005, 01:21 PM   #6
SochBAT
IIRC, SCCA guys reached well in the 300hp zone, but don't quote me. Lemme find the link for you.
Old 09-20-2005, 02:29 PM   #7
steve shadows
Im looking for keeping the car street legal as well as CARB legal in CA by keeping the cat in. so heres what I have currently
AGX.adj Struts (the red ones)
eibach pro-kit springs (black)
Front and Rear Strut Braces.
stock blown out muffler
185,000 origional miles
K and N air filiter in stock box
Chopped (unbolted) factory lower resonator
so now its "cold air"
Full complete tune up by the Stevenator (myself)
stock old ass cat.
straight pipe with no bends from cat to axle
bad 02 sensor
slight exaust leak
factory ECU
1990 COUPE Removed spare tire and a bunch of crap
inside the trunk area.
I have 225 50 15s in the front
195 60 15s in the back
Stock rear open diff well maintained
Exedy racing clutch stock pressure plate
Longer 200sx S12 shifter (for better throws when side ways on in G)
New Maf sensor.
So far the car is mighty for the small balls It should have.
I am assuming the carbon deposits from all the years of driving
have raised the compression slighly
It tests 150 all the way across on comp tests.
Any advice on how to get this puppy up there would be great.
Im thinking about SIMPLY bolt ons.
How much of a difference do the headers make and how much Can I find a set for ?
if you have a link I would greatly appreciate a direct PM.
