Old 09-29-2005, 03:06 AM   #1
t88-supra
t88-supra is an unknown quantity at this point
wiring harness wont come out
ok, so I started my swap tonight, got all the stuff from my stock 240 un-done in the engine bay. then in the passenger side, unscrewed the bolt holding wiring harness to ecu, then unhooked brown clip and completly removed ecu (I think, 1 silver piece) then when moving the harness out into firewall, it seems to be getting caught on something, also a few wires are getting really tight, did I unhook all the appropriate connections under the dash?
t88-supra is offline   Reply With Quote
Old 09-29-2005, 08:46 AM   #2
projectRDM
projectRDM's Avatar
There's a cable tie on the firewall behind the blower case, make sure it's loose. I'm assuming you unplugged the dash connector.
FORMERLY R240NA
Old 09-29-2005, 06:46 PM   #3
t88-supra
I belive so, which one is the dash connector?
Old 09-29-2005, 08:36 PM   #4
projectRDM
projectRDM's Avatar
White plug on SOHC, brown on DOHC, straight above the ECU, beside the glovebox.
FORMERLY R240NA
Old 09-29-2005, 08:48 PM   #5
driftin240
driftin240 has a little shameless behavior in the past
the wiring harness has one of those hard plastic things in it, it gets clipped down to the car, make sure its popped up and loose, i had to cut the plastic thing out so i could pull my harness.
89 RHD Hatch RB20DET
95 S14 SE 5lug
93.5 Infiniti G20
driftin240 is offline   Reply With Quote
Old 09-30-2005, 12:38 PM   #6
golfer17
golfer17's Avatar
golfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nice
Send a message via AIM to golfer17
omg, we spent forever trying to get that harness out. there is a plastic thing in there holding it in, and if u look up under the dash far enough, u can see it, the problem is, it is almost impossible to cut, and everytime u think u got it cut, u find out u didnt, but just keep trying, eventually u'll git it done.
golfer17 is offline   Reply With Quote
