Old 10-19-2005, 08:47 PM   #1
slamdawg543
slamdawg543 is an unknown quantity at this point
Send a message via AIM to slamdawg543
car wont run...
ok, since the car last ran in prestine order, i have added a t28, 550s, enthalpy tune, and z32 maf. after the install of these, i had a minor problem of the idle dipping/dying after rev's sort of like a vented bov syndrome, now the car's problem has incresed, and now will not run at all...
on start up it runs fairly normally for 3-5 seconds then chokes itself and dies. various popping occurs, and black smoke exits the exhaust before it dies
things i have checked...
-maf wiring
-timing
-unplugging the maf does pretty much nothing
-checked the injectors for leaks
-checked ecu for codes just pulls code 55
-checked for boost leaks
-tried cleaning the iacv
-i even sent the ecu back to enthalpy to check it out, and it checks out fine.
Some one please help...!
slamdawg543 is offline   Reply With Quote
