Old 12-13-2005, 01:52 PM   #1
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
Put a Haltech on my ITB ka!
Well there haven't been any events worth going to in a while, so I figured I'd work on my car. I've gotten a lot of stuff done in the last couple months.
I've never seen any good write-ups on Haltech's stuff on here, so I figured I'd do it. Here goes...
As many of you know, I built a Megasquirt modified to control ignition also, and have had it on my car for a few months. It was a great setup, worked very well for what it was. Long story short I talked to haltech and after a lot of thinking, I decided to try it out. I went with an E8, with a flying lead harness, and LS1 (corvette) individual coil ignition.
The build Quality is incredible. One look at the board in the ecu was all it took to convince me. There are easily 10x the number of components in the haltech than the MegaSquirt. That's how many more functions it performs, easily. Dave at Haltech actually installed the harness for me, and let me tell you, it's incredible! He heat shrunk every inch of wire to seal it better than the stock harness, and covered about 90% of it in flame retardant material. It's amazing.
I decided I wanted to run the LS1 coils because they are about the most potent mass produced coils available. They are NUTS. Getting bit by them hurts like hell! They have built in ignitiors too, so no need for another ignition module to control them. Paired with the custom MSD 8.5mm super conductor wires I made, it's pretty much the most bad arse ignition system you can get. And the haltech runs all of it. The wires only have about 40 ohms per foot of resistance, so it's performs just about identical to a coil over plug setup. You don't need to make any kind of custom trigger wheel for the ignition either like I did for my MegaSquirt. It just takes the signal from the stock distirbutor, easy as pie.
My megasquirt had an internal map sensor (on the ecu itself) which is an ok design, but requires you to run a vacuum line into the cabin to the ecu. It's just a design prone to failure. The E8 uses an external sensor which is much better than the internal design, and response is better because the vacuum signal doesn't have to travel to the ecu. My map sensor line is no more than a foot long, really cool.
Alright, enough talking, pics now!
the haltech installed. where is it? haha hid all the wires!
ran the harness under the manifold. You can see the wires all heat shrunk.
The LS1 coils and wires and whatnot. Made a cool aluminum bracket for them too.
coils up close
another...
a closeup of the map sensor, harness in its heat wrap, and distribution block
while Dave did the engine harness, I relocated my battery, slimmed down the chassis harness, and fuse block
Where else would you put the ECU? hahaha I love it!
And for shits and giggles...
Impressions: We got it running about a week ago and I've been tuning it since. It literally fired up the first try, and held a rock solid idle with the base map! I was amazed. It is technologically light years ahead of the MegaSquirt. I'm really glad I decided to try the Haltech out. Even with it fully tuned, the MegaSquirt couldn't hold the idle under 1krpms or it would fluctuate really bad and act up. The Haltech will hold it at 500 rpms if I want it to, and purr like a kitten. And this is with no idle control valves or anything! The tuning software is very straight forward, and easy to learn. The E8 tunes by every 250 rpms, versus the 500 with MegaSquirt. This allows much finer tuning, and extraction of extra hp.
And the best thing about the E8 on a four cylinder engine is that it has enough drivers to run the fuel injection fully sequentially and the ignition direct fire. This means each injector fires by itslef, not in pairs like the MegaSquirt, and each spark plug fires seperately, not batched like the MegaSqurit. And with the right tuning, you can get each injector to fire when the intake valve is closed, so when the fuel reaches the valve it is open. This is obviously far superior to two injectors firing at tdc. More hp and tq to be had with this setup. And having each plug fire independently is much better than firing in pairs, because one doesn't need to fire when the other does, which can create problems if you have any extra fuel in the cylinder that is not supposed to be firing.
The E8 does all kinds of other stuff too. boost control, fan control (which I'm running), tach output, wideband control, and about 10 other things I can't think of, it's crazy. You can also select the type of rev limiter you want. I did spark cut on all 4 cylinders at the same time, so it's gonna sound like all hell has broken loose, with complementary fireballs! rock on!
Cliffsnotes: the E8 ROCKS! I'm REALLY stoked I got one! If you want the most from your engine, there's nothing better. Period.
I also got some JWT cam! I can tell once I get it all tuned, they are gonna make it a whole new engine. Thanks to them. I'd suggest anyone who wants cams for their ka, get JWT. I should be getting on the dyno by the end of this week, so we'll see what the new setup makes. I'll be sure to post up the dyno!
Anyone who has any questions about their ecu's or capabilities, contact Dave at Haltech USA.
[email protected]
Regards,
Scott
RBS14 is offline   Reply With Quote
Old 12-13-2005, 02:24 PM   #2
CylonFrakker
CylonFrakker's Avatar
CylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond repute
Send a message via AIM to CylonFrakker
Sweet setup. My good friend kevin is shopping for a standalone setup for his KA-T. How hard of an install is the haltech? Can it be done by somebody who has done the usual SAFC and BCC and Speed Cut Defencer and Boost Controllers and Turbo Timers. I ask these questions to find out what needs to be done to run this setup because its either this or AEM EMS and the Haltech seems more feasible.
thanks a bunch
UGR.....SOMETHING WICKED THIS WAY COMES....
CylonFrakker is offline   Reply With Quote
Old 12-13-2005, 02:59 PM   #3
RBS14
RBS14's Avatar
the Haltech is really easy to install. Actually much easier than MegaSquirt. It comes with software that has the entire intallation manual, pinout for the plugs to the ecu and a bunch of other stuff. The wires that come out of the plugs for the ECU just have to be terminated (soldered) to your sensors, plug in the relays, a couple fuses, and you're ready to input the values to start and tune your engine.
The E8 is a far more capable ecu than the AEM unit. Even if they were comparable in terms of features, you can put the haltech on any engine you please (including rotaries). This is not so for the AEM. Hell, you can't even put an AEM ecu for a ka on an SR.
Tell your buddy to shoot Dave an email, he'll answer any questions he has.
Old 12-13-2005, 03:30 PM   #4
the head
the head's Avatar
I run an E6X on my SR it's great the new halwin software is excellent as well plus I love the fact they can run off of a nissan CAS trigger configurable inputs and outputs are also a great thing to have in a performance car. Now that I have used it I wouldn't ever go to anything else...I will post some pics of my install in the coming weeks.
the main gripe i have with the e6 is the lower resloution fuel maps (500 instead of 1k) but overall I absloutly love thier systems for ease of wiring and universality of the system
Old 12-13-2005, 04:03 PM   #5
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
sounds badass,. can't wait to see final results and some video clips in action
sncs14 is offline   Reply With Quote
Old 12-13-2005, 04:08 PM   #6
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Finally an update scooter.
Geez.
Wheres the numbers?
PS. You wanna give me the low-down on this setup for my application? The tuned ECU didn't work out....
Maeda is offline   Reply With Quote
Old 12-13-2005, 04:08 PM   #7
RBS14
RBS14's Avatar
I've got an event this weekend, so there should be some clips.
Old 12-13-2005, 04:08 PM   #8
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
we want dynos Scott!
the new setup looks sweeeeeet... I hope with fine tunings + cams, you will make some wonderful numbers with the KA.
Keep us posted pleaseeeeeee.
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 12-13-2005, 04:16 PM   #9
allmotorKA
allmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really nice
Nice improvements over the previous set up. Looking forward to seeing your dyno results!
allmotorKA is offline   Reply With Quote
Old 12-13-2005, 04:45 PM   #10
nigel1
nigel1 is an unknown quantity at this point
what kind of numbers are you shooting for?
+0 offset PWNS me
nigel1 is offline   Reply With Quote
Old 12-13-2005, 04:50 PM   #11
RBS14
RBS14's Avatar
I'm hoping for around 175 peak hp. maybe more, maybe less, I don't really care that much. I want a big, kickass powerband, and I know it'll have that, so it's all good.
Old 12-13-2005, 05:17 PM   #12
Maeda
Maeda's Avatar
Thats wussy talk.
I want to see 200 RWHP with that fat powerband.
Old 12-13-2005, 05:20 PM   #13
Maeda
Maeda's Avatar
Scooter are you crashing at my place for the event?
Old 12-13-2005, 05:45 PM   #14
RBS14
RBS14's Avatar
I'm not sure, either there or up with Baby. I'll call Aaron when I get out of class tonight.
I'm gonna try and hit 200 with stock block (Headwork being the only exception). Eventually....
Old 12-13-2005, 09:13 PM   #15
ootranceformeroo
ootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to behold
Send a message via AIM to ootranceformeroo
you crazy man you scott! when you commin back up bro?
Gorgeous Garage
Touge Friends
CrabDrifting.com
Drift Unit
ootranceformeroo is offline   Reply With Quote
Old 12-13-2005, 10:21 PM   #16
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
ITB's and ITC's on a KA! HOTSTUFF!!
I hope you dont mind me asking how much this setup up cost and how many hours you put into it. What are the plans to do to the bottom end when you start building that up?Just anything you can do to allow the motor to rev higher? I'm basically wondering what the goal is for the motor, so far the only thing I can tell is you want a broad powerband which you should have no matter what noting the motors displacement. But how much hp is the end all goal and to what rpm? Have you ever thought of making a plenum so that way your motor is not inhaling hot under the hood air?
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 12-14-2005, 01:23 AM   #17
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
going ITBs was the point, my only thinking would be to do some form of a hood mod, similar to what cowl induction was used for.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 12-14-2005, 04:17 AM   #18
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
Thumbs up
Sideinduction scoop? ie 1967 Chevelle SS scoops,just a rise on each side of where the cowl is(instead of cowl induction)
Back to topic: Holy shit thats a hot ass ka! Did you ever post specs of your actual ITB setup? Maybe I just don't remeber.
Ghettokracker71 is offline   Reply With Quote
Old 12-14-2005, 04:35 AM   #19
Healtoeae86
Healtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really niceHealtoeae86 is just really nice
do you happen to have the wiring diagram for the LS-1 coils? Im trying to do the same thing, but for my corolla and cant find the diagram fro wiring on the ls-1 coils. Thanks!
-ash
Healtoeae86 is offline   Reply With Quote
Old 12-14-2005, 08:28 AM   #20
RBS14
RBS14's Avatar
In the not too distant future, I'll be running ducting to the velocity stack inlets. I have watched air intake temps on the laptop, and they aren't that bad. rarely gets much over 115*f. Air vents will take that down to ambient.
specs on the ITB's? GSXR 1000 (2003) Throttle bodies mated to a chopped off stock intake mani. I'll be making a new one in the future tho.
Ash: email Dave at haltech. He has the diagram.
Old 12-14-2005, 12:09 PM   #21
ca19det
ca19det's Avatar
ca19det is an unknown quantity at this point
firstly, i love your setup, i am sure it sounds like the shiet!
i am running ahaltech too on my CA18DET and couldnt believe how easy it was to install, i simply spliced into my stock harness for CAS, Ignition and other sensors and jsut ran wires for the sensors i needed to add like MAP, water temp, air temp...
i am about to use the same GSXR1000 ITB's on my CA19DET motor with a custom plenum and a cut 8 port JDM intake manifold..
i was wondering, did you use the Suzuki GSXR TPS? and how did you plug the injector boss' on the ITB's (left the ol injectors in there or welded them up??)
thanks
set up looks awsome, i wanna see/hear some vids..
CA19
CA18DET - no oil squirters, stock bottom end, T3/T4E, Haltech 550's, Tomei ProCam Kit etc..
ca19det is offline   Reply With Quote
Old 12-14-2005, 12:19 PM   #22
RBS14
RBS14's Avatar
John: for your KA-T I'd suggest an identical setup to mine. Pretty much as good as it gets. Only difference is that you'd run a 2 or 3 bar map sensor instead of the 1 bar I'm running. And get the haltech boost control solenoid, and control boos with the Haltech also. That way you can get rid of EVERY peice of electronics you are using for your engine.
CA19: Yeah, I used the GSXR TPS. I found some nuts at home depot that fit just perfectly into the holes for the injectors on the TB's, and JB welded them in, and sanded down the JB so it's follows the port shape of the TB. Same with the "secondary" butterflies.
Old 12-14-2005, 12:24 PM   #23
ca19det
ca19det's Avatar
thanks
i'll eb starting my project this weekend and hopefully install after christmas and new years... always wondered how a ITB set up would work on a boosted CA? it may only make a few couple ponies, but i am sure the sound will be worth it.. i am already making 305whp, so i am good... looking for more response.
thanks
Old 12-14-2005, 01:22 PM   #24
RBS14
RBS14's Avatar
it'll definately get you more response. That's what I like the most about it.
Old 12-14-2005, 02:02 PM   #25
NemeGuero
No more nissan.
NemeGuero's Avatar
Gawd damn thats bad ass.
Where did you put the fuse box? And what did you trim out of the engine harness?
How hard was it to relocate?
Old 12-14-2005, 03:23 PM   #26
meatish
meatish's Avatar
meatish is a well-known jackass
Mmmm LS1 coils.. i love your ignition setup.
Mr. Pibb + Red Vines = CRAZY DELICIOUS
-Dont wanna be a drifter no more..
Im not a drifter i just crash a lot.
meatish is offline   Reply With Quote
Old 12-14-2005, 04:07 PM   #27
papa
papa is an unknown quantity at this point
Send a message via AIM to papa
love the set-up..deff post up the dyno numbers when you get em
muAh
papa is offline   Reply With Quote
Old 12-14-2005, 04:26 PM   #28
Andrew Bohan
hooray for In Tha Butt KA's
lookin good scooter
Old 12-14-2005, 07:38 PM   #29
Al_S14
Al_S14's Avatar
Al_S14 is an unknown quantity at this point
Send a message via AIM to Al_S14 Send a message via MSN to Al_S14
how do you regulate idle air flow with out the IAC?
Al_S14 is offline   Reply With Quote
Old 12-14-2005, 08:28 PM   #30
sLiDewAys
sLiDewAys is an unknown quantity at this point
fukin scott. i swear you are on a roll man. u gota let me knwo when ur in sc. i want to see this thing.
sLiDewAys is offline   Reply With Quote
